2001 S-10 vibration at 45 mph and up??? - S-10 Forum
post #1 of 20 Old 02-18-2012, 02:11 PM Thread Starter
njrextreme's Avatar
User is: njrextreme is offline
I was wondering if anyone had a similar problem as me? What happens is at 45 mph and up my truck starts to hum/vibrate. Its not harsh but I can hear it and feel it in the gas ped.. If I put it N and decell it is still there untill it reaches 44 or less. I replaced the U-joints front and rear last night and it still is there. My rear one was shot so im glad I did replaced them. I also rotated the tires. I am going to do my front brakes and inspect the front wheel bearings tomorrow. Any other ideas or parts I should be looking for that cause this??? The truck is a reg cab, auto, 2.2L
Thanks,
Nick
post #2 of 20 Old 02-18-2012, 02:17 PM
User is: knock9876 is offline
Re: 2001 S-10 vibration at 45 mph and up???
tires need balanced
post #3 of 20 Old 02-18-2012, 02:20 PM Thread Starter
njrextreme's Avatar
That would cause a humming noise? I just put two new tires on the truck a couple months ago. I rotated the new fronts to the rear and no change at all in the noise and the vib..
post #4 of 20 Old 02-18-2012, 03:08 PM Thread Starter
njrextreme's Avatar
Originally Posted by knock9876 View Post
tires need balanced
I checked for all my weights and it seems I may have lost one on the rear. Thanks for the suggestion. Ill update when I put another weight on it.
post #5 of 20 Old 02-18-2012, 03:13 PM Thread Starter
njrextreme's Avatar
I found out it did have the weight on the tire, 0.25. It just dont have any lead on it.
post #6 of 20 Old 02-18-2012, 06:14 PM
no not having a tire balanced will cause vibrations you can get tires balanced pretty cheap
post #7 of 20 Old 02-18-2012, 06:43 PM Thread Starter
njrextreme's Avatar
I hear ya, I have a machine I can use at work. I will check them out.
post #8 of 20 Old 02-18-2012, 10:34 PM
yep once there balanced it should glide smooth
post #9 of 20 Old 02-20-2012, 11:55 AM Thread Starter
njrextreme's Avatar
I put new rotors and pads on and packed the bearings. All looks ok there. I need to check the tire ballance tonight. I hope thats all it is. It still has a vibration at 45 and up mph.
post #10 of 20 Old 02-20-2012, 12:29 PM
im telling you that's what it is lol it will b smooth as glass when you balance them
post #11 of 20 Old 02-21-2012, 12:07 AM Thread Starter
njrextreme's Avatar
Sorry bud, tires are balanced perfect. I'm down to a warped drive shaft or a trans issue. It's not horable but somthing is messed up.
post #12 of 20 Old 02-21-2012, 12:10 AM Thread Starter
njrextreme's Avatar
Or a rear end issue. I'll figure it out.
post #13 of 20 Old 02-21-2012, 08:57 AM
ok then you may have a bent wheel if you have a spare tire and wheel you can check them one at a time by swapping them out unless you have already tried that,did the truck just start doing this?and did you replace that tires lately because you could have got a blem i have got them before and they shake it pretty bad
post #14 of 20 Old 02-21-2012, 09:15 AM
chaospartners's Avatar
User is: chaospartners is offline
Send a message via AIM to chaospartners
Hmm im having a simular problem with my 2003 4.3 5speed i just picked up... it only seems to do it above 45.. aint bad or notting just anoying. Dont the drive shafts have some kinda balance ring on them? im thinking i need the drive shaft balanced but i also havent changed or checked my u joints yet! so that could be my problem.
03 Extreme, 4.3 5speed! core short throw shifter, custom y pipe, no cats, with flowmaster duals..
post #15 of 20 Old 02-21-2012, 10:50 AM Thread Starter
njrextreme's Avatar
Check the u joints out. If they dont move easy when the drive shaft is off the truck they are bad. they have metal weights on the shaft. I did not see a spot where I could have lost one. My problem seems to be more off a humming or a shutter. Its not a shake in the stearing, its a vibration that starts at 45 mph and up. My wheels are good. No cracks or bends. They are stock swirls and I have a decent side wall. I am going to put a set of xtreme rims w/ new tires on it soon anyways.
post #16 of 20 Old 02-21-2012, 11:10 AM
andyswmr714's Avatar
User is: andyswmr714 is offline
Send a message via AIM to andyswmr714
did you drop the truck? If you did you re set the pinion angle?
How are the mounts....trans/motor. If any of those are broken it can change the driveline angle.
'02 2.2 flex fuel, dts2 built engine, tuned, and saving for turbo goodies
sold '99 4.3 S10 5spd, 3/3 spindles springs and leafs, taylor wires, cold air maf and intake, e-fan, poly mounts
sold '99 Extreme 2.2 DTS Turbo kit stage 1, 255 walbro, MEGASQUIRT 2
post #17 of 20 Old 02-21-2012, 11:24 AM Thread Starter
njrextreme's Avatar
No drop yet. I have the parts for a 2/3 drop but have not got around to it yet. Ill check the mounts, thanks.
post #18 of 20 Old 02-21-2012, 11:43 AM
yea mine is a vibration to! ill check my u joints next chance i get! when i sold my 97 the guy that bought it said that the driveshaft had lost its balance ring thats why it had a vibration from drive line idk if he was just blowing smoke or he knew what he was talking about
post #19 of 20 Old 02-21-2012, 12:06 PM Thread Starter
njrextreme's Avatar
There may be one but all I seen was metal tabs welded to it. I think I may put it on the rack and have someone put it in gear and speed it up to 45 and look under it.
post #20 of 20 Old 02-21-2012, 10:43 PM
Well i had my tires balanced at work today and i have 2 bent wheels, but just balancing them took the shake out!! so im on the hunt for some new extreme wheels.
