2000 Chevy S10 Engine noise - S-10 Forum
post #1 of 6 Old 02-24-2011, 10:29 PM Thread Starter
User is: ch70357 is offline
I have done a lot of researching on here pertaining to the noise I am hearing in my engine, but had a hard time finding a thread that encompassed all of the variables that I am looking for so I decided to post.
I purchased my 2000 Chevy S10 LS with the 4.3L V6 about 18 months ago. It was supposed to be a project but it did more sitting in the garage than anything else. It sat for about 4 months prior to me actually finding the time to work on it without being started.
There is a ticking noise coming from what SOUNDS like the lower half of the engine. The sound is more prominent on the drivers side and stays in sync with the RPM's. Based on some of the videos I've seen here, it sounds like a lifter, so maybe the sound is misleading and it is not in the bottom half. My initial thought is that it is not a rod or bearing because they usually make kind of a "sloppy" noise and not a clear tick like I am hearing (please keep in mind, I make no claims of being a mechanic at all, but this has been the case in my super-limited experience).
Here is a link to a video that sounds like what I have:
After running it for 10 minutes or so the sound dissipates and is completely inaudible from inside of the truck, but slightly noticeable from the outside. I have tried MMO but that didn't make a difference, and my last oil change I went to 5W-30 synthetic with no result. The oil pressure is perfect and and there are no oil/coolant leaks.
The vehicle has 88,000 miles on it and the previous owner kept it in pristine condition and supplied all of the maintenance records.
So, that being said, is it a possibility that I did some type of damage by not running it for 4 months? Could it be a lifter? Or should I just prepare for the death of this truck.
Also, considering I know very little about working on vehicles, would replacing the lifters be too difficult for me to embark on by myself if I decide to do it?
This forum is awesome and thanks for your thoughts!
ch70357 is offline
post #2 of 6 Old 02-25-2011, 10:26 PM Thread Starter
Re: 2000 Chevy S10 Engine noise
Bump...
ch70357 is offline
post #3 of 6 Old 02-26-2011, 01:48 AM
User is: deerman is offline
Maybe a lifter? Have you tryed SeaFoam with the oil?
deerman is offline
post #4 of 6 Old 02-26-2011, 02:21 AM
a mintruck is never done
sonoma2bdifferent's Avatar
User is: sonoma2bdifferent is offline
sounds like my 2002 sonona . i fist skimped cheep oill ,next time i used high milage oil slarted slowygettin louder . eventually was fading afay on start up whill warm . not so soud added some kind of oil aditive detergent i was told to get from advance in a yellow bottle ran it 2 weeks i think and it got better basicly i had a cloged lifter onth e passenger side. the oil pressure went up with each click .now days i start ti hear it faint i cange oil . full synthetic and a 4x4 filter to hold a even 5 bottles of oil . sorry about the spellin im fallin asleep with slep med th doc told mo to use
post #5 of 6 Old 02-26-2011, 09:32 PM
2.2 Extremist
GMC Motorsports's Avatar
User is: GMC Motorsports is offline
I would say it sounds to me like you should try adjusting your rockers, but it sorta sounds like the idler pulley, my 96 made the same sound but it didn't get louder with rpm's,
2000 GMC Sonoma SLS
ECSB 2.2L Flex Fuel L43 bored 0.40, 0.20 head shave, 5-Speed, 4.10 gears, Space Blue Metallic, Graphite Int, OBX Header, straight pipe cat delete, Thrush Welded, urethane motor mounts, ZQ8 sway bars, Hurst Short Throw Shifter, ClutchMasters 9lbs flywheel
Other Rides: 09 Canyon 5.3 ZQ8, 05 Duramax, 85 Monte Carlo SS.
post #6 of 6 Old 02-27-2011, 02:16 AM
i cant say for shure about 2000 but my 2002 w 4.3 ,the rocker arms can't be adjusted ,but the nut that holds it down might could get loose mabe. i have heared of the rocker arm splitting at the pushrodr ,they are though.either way i would pull of the valve cover the wires will need slack, i unbolted items from the inner fenders to look at mine .
