The Original VO
2 grand lemon. what would u do?
hey whats up guys, im kinda frustrated with my truck at the moment. heres whats goin on:
bought for $2150 95 ext cab s10 4.3 5 speed (nv3500) 176,000 miles came with 3 extra wheels with all season tires on them that the guy was using for winter. what ive had to do already: PS pump 50 Serp. Belt 25 Tensioner pulley 18 Idler pulley 19 Efan to replace bad fan clutch 50 Fuel tank 73 fuel sender 50 still needs: idler arm 1 tie rod end upper balljoints oil cooler lines battery then today i was driving it and i figured out the clutch slips if u floor it in 4th goin 25. i was told that was one way to test a clutch. that cant be normal can it? so now ive got 2600 bucks into this thing, and it might need a clutch. should i just give up and drive it till it blows up? would u put more money into it at this point? any input is appreciated. thanks! |
rolling work in progress
Re: 2 grand lemon. what would u do?
it sounds common after 170000 miles.
You...Tonight
don't be discouraged man alot of that stuff you listed if it's factory is lucky to have made it to 176,000 miles. if it's on good shape i say fix it up
It's not a lemon. Those are basically things that are routinely replaced after time.
stuff gets old and starts breaking...its sucks you bought it and it decided to but it happens man
<3 redheads
you'll be alright
Newb
new old car= new old problems
Registered Neanderthal
Finish fixing it. The remaining stuff is easy to do. Idler arm & tie rod end are cheap. The ball joints are easy, oil cooler lines too.
A careful test drive and quick inspection would have turned up alot of this stuff, but you must have noticed some of it. |
The Original VO
thanks guys!! /thread |
94 2.2, feel the power?
Well, look at it this way, once you get that basic routine stuff fixed, it should be good to go. You have the "Z" engine with TBI which pretty much lasts forever. It's also a common engine and easy to work on.
Local Tech
i understand being frustrated, but you didnt buy a lemon...... you hbought a 2000 dollar vehicle
I Type Slow Too...
I have to echo everyone else's sentiments... it's not a lemon it's just an old truck. Trust me so far you've gotten off pretty easy... get back to me when you need to replace the intake mainfold gaskets, heatercore, and rebuild your transmission Valve body... I have had to do all of this on my wife's Bravada. My truck so far just a rear main seal, a clutch (unfortunately two completely separate repairs), Alternator, Battery, ECU, and all kinds of other little piddily crap.
Ahh the joy of not having a car payment... Edit: Oh and FWIW My wife's Bravada: $2200 My truck: $1200 both paid in cash. Last edited by Slow_S10 : 11-06-2009 at 10:10 AM. |
forum idiot
well you really just paid too mych for the truck to start with..
Ditto to all of that....especially paying too much. Sounds to me like its worth 1200 bucks. But still its better than car payments and if you fix all that crap you can probably get another 10 years out of it.
I say you did overpay somewhat. FOr continuingto fix it I would say if the body and frame are in good condition I would spend the next~$300 and finish the repairs. Did you know it had all these problems when you bought it?
Whether its worth continuing to spend money on is your call honestly. If the motor and trans are in good shape, and the frame/body are solid still, its not a lost cause yet.
I had to actually INSTALL my whole wire harness and basically everything that goes in the engine bay on my S10, so when you look at the grand scheme of things, its not really THAT bad honestly. |
workin it !
just finish fixing everything and you'll have a very dependable truck
you'll be happy once you get everything taken care of r e l a x....it'll be OK ! |
