1999 S-10 rear brake lock?!?!?!?! - S-10 Forum
post #1 of 10 Old 08-11-2013, 08:10 PM Thread Starter
User is: asphaltlou is offline
Hey everyone,
I have a 1999 2wd 2.2L Auto S-10! My passenger rear brake locks up when I first start driving, when its damp, dry it doesn't matter. The brakes are brand new. Like I read in other posts. I can't drive in slow traffic the pass. rear locks up, then the ABS kicks in. No brake fluid leaks, no rear axle seal leaks, bone dry and clean. I finally took it to the dealer, he said e-brake cable was to tight. I drove it home no problems and it stopped like it should. Today different story, locks up again. And as I was driving up to garage I lightly tapped the brake and it almost put me through the windshield. It startled me pretty bad, I don't want to drive this anymore. Any ideas. Someone has got to have a fix for this! Thanks!
post #2 of 10 Old 08-11-2013, 08:20 PM
eMrock32's Avatar
User is: eMrock32 is offline
Re: 1999 S-10 rear brake lock?!?!?!?!
Take it back apart. You need to first check the adjustment and if that's OK, check the cable. Stepping on the brake shouldn't engage the parking brake. They are virtually 2 different setups.
MAYBE if the cable is tight, it may throw the drums out of adjustment enough that it could lock up. If so you can just remove the cable until you find a replacement.
-98 S10 Wagon (cut through) 3-4 drop w/ spindles, springs, shocks, and blocks. 325,000 on body fresh motor rebuilt by me. 2.2 with CAI, cavalier cam, exhaust. WS6 Wheels
-72 Monte Carlo. Mostly restored. 350 numbers matching 3 speed trans. More restoration happens every weekend.
-95 Nighthawk Street fighter. Mirrors, and turn signal delete. Radioshack jet kit. Bored stock pipe. CAI. 11.6 1/4 mile
eMrock32 is offline
post #3 of 10 Old 08-11-2013, 08:44 PM
AWD V8's Avatar
User is: AWD V8 is offline
Drum brakes I'm assuming.
Remove the drums on both sides. Compare the lining of the forward shoe on each side. The forward brake shoe should have the short lining compared to the rear shoes.
Check that the wheel cylinders are not seized. You can do this with the hardware installed. Use a large screwdriver to lever the top 1/3 of the front and rear shoes towards the center of the wheel cylinder. If both shoes move forward and back when prying from each side the wheel cylinder is free.
Check that the shoe material appears identical side to side.
AWD V8 is offline
post #4 of 10 Old 08-11-2013, 08:44 PM
always something new
S10dude's Avatar
User is: S10dude is offline
you need to do a better inspection....some thing is not right inside drum that locks up...
All truck pics
S10dude is offline
post #5 of 10 Old 08-11-2013, 09:40 PM
B4U Task Force
Rhotpursuit's Avatar
Possible contamination..fluids
U.S.C.G. "So others may live"
Apple Red 96 SS
post #6 of 10 Old 08-12-2013, 06:40 PM Thread Starter
Now, this morning I leave for work both rear wheels lock up. I stopped to back up and turn around, and truck would barley move. I had to give it a good amount of gas, I drove back up the drive way and I could smell the brakes getting hot. So I go jack it up and pull the tires off and I was expecting to beat the drums off, but they just pulled right off, no problems! What gives?! I put it back together, drive it around and no problems. Go to clean up, come back out and it locks up pulling down the drive way. I said thats it and parked it. I can't afford to just start replacing parts if it's not the problem, but I am lost!
post #7 of 10 Old 08-12-2013, 08:26 PM
F117EWO's Avatar
User is: F117EWO is offline
A corroded wheel cylinder could potentially cause the brakes to not release immediately.
Just a thought. Wheel cylinders are also cheap and easy to install. Not sure what else could cause your problem.
Jake
2002 S-10 2.2 ltr 5 speed, reg cab, step-side
1992 S-10 2.8 ltr V-6, 5 speed, extended cab
2012 Acura TL, auto (bone stock)
2006 Harley-Davidson Springer Softail
2010 Chevy Suburban 6.6 Duramax diesel
1996 GMC Suburban 6.5 turbo diesel
F117EWO is offline
post #8 of 10 Old 08-12-2013, 08:28 PM
eMrock32's Avatar
Try releasing both cables for the ebrake first. Put the rear up on stands. Have someone press the brake and you spin it. If it locks up again, you have a problem with your wheel cylinders. Make sure they are adjusted properly and a shoe isn't going off its curb as well. If you just replaced them, it should be almost impossible to have that happen. I'm really leaning towards wheel cylinders....
eMrock32 is offline
post #9 of 10 Old 08-13-2013, 06:45 AM Thread Starter
Thanks for the info guys. The ebrake cables where backed off, by the dealer a few days ago. I drove it around last night and absolutely no problems. i jacked it up and spun the rear wheels and I don't hear anything rubbing, they appear to be free. I am leaning towards the wheel cylinders. I am going to try to drive it this morning, to see what happens. This is frustrating! Thanks again.
P.S. I miss my 78 Chevy 1/2 4x4!
post #10 of 10 Old 08-13-2013, 05:14 PM
MEP1's Avatar
User is: MEP1 is offline
Pull a drum off, take a pic and post it. Make sure you say which side it's from. It might be put together wrong, even if it went together the way it was.
MEP1 is offline
