1998 Sonoma Surging issue - S-10 Forum
post #1 of 4 Old 03-11-2017, 02:56 PM Thread Starter
User is: JCarnes is offline
I have seen somewhat similar threads around this site, so please forgive me is this is redundant. I just have not ever seen a clear answer on the issue. My 1998 Sonoma is fitted with the 2.2 and has over 230,000 miles. When I am at cruising speeds mainly between 40-60 mph, I can hold a steady peddle and the rpms will rise about 100 rpms over and over. When adding a little more throttle it seems to go away, and it also seems to be non-existent when I reach 60mph and above. I have changed the TPS, and had the transmission rebuilt twice. This is super annoying, and other than this problem the truck seems to run and shift great. Any opinions and knowledge is greatly appreciated.
JCarnes is offline
post #2 of 4 Old 03-17-2017, 10:21 PM
User is: Century7667 is offline
Re: 1998 Sonoma Surging issue
Honestly, the best tack I would take would be to get a good scan tool that had data logging capability (not just a code scanner -- codes can only take you so far), so you can monitor what's going on during the surge. Otherwise, you can guess at parts. I thought the TPS was a pretty good educated guess, but it was just a guess (and the wrong one apparently).
I use Ease Diagnostics software on my laptop. About $200 for the software and cables. You can spend that much in parts fairly easily. In your case, since you can replicate the issue pretty easily, so something should stand out. You just need to learn to interpret the data. You may find you have an odd signal from the O2 sensor or maybe some weird fuel trim numbers. There are lots of online resources for interpreting that data.
...or you can pay a mechanic to use his scanning gear to do the same.
Ken T.
post #3 of 4 Old 03-17-2017, 10:44 PM
AWD V8's Avatar
User is: AWD V8 is offline
Android phone?
Torque app, 5 bucks + 10 bucks for an OBD adapter
You can graph any live data. I've used it for many years. Best value in OBD diagnostics
You can monitor your fuel trims O2 voltage to see if it's a vacuum or fuel problem.
AWD V8 is offline
post #4 of 4 Old 03-19-2017, 06:42 PM
rgrah01's Avatar
User is: rgrah01 is offline
Sorry to hijack the thread but what OBD adapter would you recommend? Would this also work on the ABS?
Assumption is the mother of all fups....
rgrah01 is offline
