1997 s-10 engine swap!
I have a 1997 2wd s-10 pick-up that has a 4.3 vortec vin x engine in it. I picked up an engine that came out of a 1999 4wd s-10 pick-up that had a 4.3 vortec vin x also. The junkyard said I needed to use the bell housing bolts that came out of the 1999 s-10, and the flex plate. Just wondering what the difference is. Will I run into any problems? Any info would be helpful.
Thanks a lot Scott |
Done with the whinners
Location: Where men act like men and don't cry User is: OffLine |
Re: 1997 s-10 engine swap!
Well the first problem you ran into is you posted a second gen question in the first gen section.
Location: Indianapolis (Castleton), In User is: OffLine |
moved to second gen section
