s10***** whore.
xtreme kit on 95-97 blazer/jimmy?
can it be done if getting the proper ( 4dr / 2dr ) kit. also i assume id be able to get it all from the dealer no? if so what would be the cost. or would it be better to find a 98+ blazer. an get the kit
The Der
Re: xtreme kit on 95-97 blazer/jimmy?
Your wanting to put a xtreme kit on a 95-97 jimmy or blazer?
First off its a four door the sideskirts and rear fender flares will not work from gm you would need an aftermarket (usually fiberglass) kit. As there was never a 4 door xtreme from gm. Second dealer would be way too expensive...look in the classified here or on ebay Third yes it will work If your going to use a jimmy then you will need to convert the front end to an s10 94+ and use a 98+ s10 metal bumper and x valance. You can mold the x kit to the sonoma/jimmy bumper but it would be easier to swap the front end If your using a blazer then all you need is the 98+ metal bumper and x valance Last edited by dernoma : 06-14-2006 at 07:44 PM. |
i looked into this after seeing fetto's and another guys on here here is what i found
http://i58.photobucket.com/albums/g2...e/04e75982.jpg 95-04 Chevy Blazer& GMC Jimmy 4-Door Ground Effects Price $240.00 http://boa-fx.com/pages/9/index.htm is the compnay still sellin them here is fetto's with the ECC xtreme roll pan http://i58.photobucket.com/albums/g2...8_158_full.jpg then i would suggest getting the paintable 98+front bumper and an xtreme valance to complete the look hope this helps some joshey edited since the IMG tag is turned off Last edited by hipoblaze : 06-16-2006 at 05:20 AM. |
