Wont Start
I have a 96 Blazer with the 4.3L, Auto, and 4X4. It is really hard to start and runs kinda crappy when it does. Hooked up a fuel pressure tester today. With the key on it goes up to 55-60 PSI until the pump shuts off, then it goes straight to 0. Cranking it has 60 PSI and running it has 54 PSI. I think the pump is getting kind of weak, but it also seems like the regulator might be shot. Any ideas?
Re: Wont Start
idk but mine does sum weird stuff like dat, sum time it will start up fine then afta da fuel pump turnes off itwill idel really ahrd then just die, then when i go to restart it it takes a few secs it wont come right back on, so if u fig it out let me kno so i can fix it on mine to
Registered (Ab) User
Re: Wont Start
How long has it been since you changed plugs, wires, cap & rotor? |
Re: Wont Start
Dont know when they were last changed. I just got this about a month ago. Didnt run when I got it. So far all Ive done is replace the alternator, It was shot, and test the fuel pressure.
Re: Wont Start
It's best to start with the basics. Replace the plugs, wires, cap & rotor and see how it runs then.
I piss excellence
Re: Wont Start
You pretty much answered your own question Sounds like a fuel pump issue...could be wrong tho... Like yogi said start small....plugs/wires/cap rotor/ even a fuel filter. |
Re: Wont Start
my fuel pump is brand new tho i hope its not that, i wnna do my wires and stuff this weekend, but i wanna up grade it all, what size should i get?
