where is my fuel pump in my jimmy envoy?
ok, i let my "friend" work on my truck. it stopped working on day for no reason. it was working fine before that. he sprayed starter fluid in the intake and it didn't start. we checked the pressure valve? by the back of the engine and he said it had pressure. i replace the ignition control module, distruber cap and rotor. nothing. i tried the starter fluid by myself and it tried to start. thus im not getting fuel. i wasted a bunch of money.
anyway, is the fuel pump inside my tank or external? the reason i ask this is because there are lines that go to the drivers side back of the truck and say fuel all over them. so im figuring that my fuel pump could be there. the lines go inside a close box. i also checked my fuses and they are good so where is that fuel pump on a jimmy envoy? gregory a. |
Under Construction
Re: where is my fuel pump in my jimmy envoy?
in the gas tank
what all that crap that goes to the back of my truck then? 2 metals lines and a large plastic
The Dreamsicle
the lines running back into the bumper area? those are the emission conrtol lines. thats where it gets rid of the gas fumes and stuff.
alright cool. what kind of fuel pump would you guys recommend for a stock truck. i looked online and most were near $300 or more. thats a lot cash for a little part. so keep price in mind
everyone has been veryful, thank you gregory a |
The Dreamsicle
i don't know about others, but i bought mine from ebay. brand new $150. I ran it all last summer so far and it hasn't skipped or anything yet.
god damn. this thing is big and all plastic. 275 bucks. does anyone have tips for replacing it? im sure show how to take it out but how do i put it back in, is there a certain way? and is my gas guage going to get messed up?
gregory a |
The Dreamsicle
tips: when you take out the tank, make sure the top of it is clean so that you dont get any dirt inside of it. run most of the gas out of it so it's easier to remove from the truck. mine was tricky getting the pump back in, its held in by a snap ring. you'll see how it works when you get to there, its pretty simple.
my pump was working just fine and i replaced mine to get the gas gauge working since that is a common thing for that part of it to go out. your gauge wont get messed up as long as you dont break the float off, which is pretty strong so dont worry about it. |
Take note: there are 2 different fuel pumps. One for the 2dr and one for the 4dr. You need to buy the correct one because they are different.
u said it had pressure, how much pressure was there, i believe it requires 60 psi. are you sure its the pump thats the issue? not doubting you, just wondering, sucks chasin shit down and just throwing parts at it
