When my dash lights should light up my turn signals light up solid
Old 07-05-2008, 10:20 AM   #1
When i light up the lights in the car at nite there are no dash lights that light up the tach or the spedo
but they light up the turn signals
what did i do when i pluged the dash cluster back in after replacing the bulbs did i mess somthing up anyone have any ideas Please
Old 07-06-2008, 01:23 AM   #2
The Dreamsicle
cpolaris502's Avatar
Re: When my dash lights should light up my turn signals light up solid
i dont know, but right now both of my turn signal lights are on too because i have a blown blinker bulb. i forgot to check the fluid in them.
Old 07-06-2008, 10:31 AM   #3
Quote: Originally Posted by cpolaris502
i don't know, but right now both of my turn signal lights are on too because i have a blown blinker bulb. i forgot to check the fluid in them.
I'm confused what fluid you forgot to check fluid in the blinker bulb
I took the dash out yesterday and messed around wasn't even remember what i was doing but after a few the lights started to work again but I'm still confused
there are 4big lights i think they have a blue base to them
but they are one the corners like right now the gas guage vault guage oil pressure and temp guage but there is another spot in the middled for a bulb but there is no bulb in there wondering if that is why the middle of the dash is so dime when the rest of the lights are on don't wanna pull it out and mess with it again
Old 07-06-2008, 12:56 PM   #4
The Dreamsicle
i was joking about checking the blinker fluid. lol.
Old 07-06-2008, 01:41 PM   #5
ah ok cool
atleast now i know how to take the dash out and replace the bulbs without breaking anything LOL
Old 07-06-2008, 03:00 PM   #6
it happens
chevyrules05's Avatar
Old 07-06-2008, 03:17 PM   #7
perhaps you crossed some wires or plugged something it wrong
Old 07-06-2008, 04:09 PM   #8
no wires to touch back there all it is is one conectore that is bult into the dash and also the cluster when you put the cluster in it conects automaticly just bulbs in the back
Old 07-11-2008, 01:42 AM   #9
V8 with bags
V8Blaze's Avatar
tap the headlight switch ground wire and run a ground to the steering column bracket. its probbaly an iffy ground somewhere, this truck worked on my first gen
Old 07-11-2008, 02:19 AM   #10
eCkO
INFAMOUS's Avatar
x2 its your ground wires..there are multiple grounds in the front..
Old 07-11-2008, 06:09 PM   #11
Has Training Wheels
beaniebmx's Avatar
make sure you plugged all the wires in fully, one sounded like it clipped, but didnt, none of my gauge lights worked and neither did my console shift lgihts
Old 07-18-2008, 09:12 AM   #12
after i had removed the dash and put it back in it was working fine than about a week latter it hapend again so when i was sitting in the car wash where it was dark i decided to just bang on the cluster so i hit the cluster a few times and it started working fine
do you think it may be a conector problem or just a bad cluster
Old 07-18-2008, 11:20 AM   #13
Registered (Ab) User
Yogi's Avatar
If you didn't have the problem until you took out the cluster, I would suspect the connection on the plug.
Old 08-26-2008, 06:26 PM   #14
No mor bags juice or dubs
juicedondubs's Avatar
next time it does it turn your hazards on then off and see if that affects it. the hazard switch is in series with this circuit and can cause this problem if the pins arent perfectly lined up.
Old 09-02-2008, 12:14 AM   #15
there are not wires on the back of the dash to plug in just has the conector slot where the dash cluster goes right into the dash board
it has been hapning when it happesn i just make a fist and nock on the cluster hard usualy 1 or to wakes with the hand it corects it self i am wondering what is going on with this
Old 09-02-2008, 02:04 PM   #16
have you tried the hazard switch yet? you could have moved it out of position removing the cluster.
Old 09-02-2008, 08:04 PM   #17
its not the hazard switch becouse all of a sunden i could be driving in the dark and they will switch to hazard and the dash will go off
Old 09-04-2008, 01:17 PM   #18
I piss excellence
Kaznlilgreenmen's Avatar
I think I understand your problem..? When you turn your headlights on you don't get any illumination on your cluster? Have you check your dimmer switch?
Page generated in 0.60070 seconds with 31 queries
[Output: 97.93 Kb. compressed to 90.68 Kb. by saving 7.25 Kb. (7.40%)]
