eCkO
wheel bearing/hub???
okay i have a 2001 chevy blazer 2dr 2wd and last night i started hearing a funny noise so i turned the radio down and it sounded like metal on metal. first thing that came 2 mind... wheel bearings. little did i know that the cost a arm and a leg also they got to be pressed in. but yeah if any one knows where i can get them online for cheaper feel free to post. also any tips on any thing to.... thanks |
Re: wheel bearing/hub???
i dont believe they have to be pressed in. you get the hub, remove the brakes and the 3 bolts that hold it in and reverse to install.
Registered (Ab) User
What he said^^^^^^
Someone else recommended BCA Hubs as a good replacement, and a lot cheaper than GM. You might try BBB Auto Parts. |
can you just clean inspect and repack with synthetic high presure grease??
I think that the only way to get them open is with a cutting torch.
eCkO
Ted's emporium.
Yeah,i Was The Guy That Said To Use Bca Hubs.same Thing As The Delco But Cheaper.i Just Put One On My 01 Blazer.took About 30 Minutes Or So.take Off Caliper,pads And Rotor,take Out 3 Bolts That Hold Hub On.unplug Sensor.then Do The Oppisite To Install.
edit:bca part number 513200 Last edited by blazerman : 04-08-2008 at 11:08 AM. |
Burnt out
How good have those BCA wheel bearing held up? I've always heard to get Timken but the cheapest I've found them are $180 each.
***Edit*** Nevermind those are $226 each, I'll stick with Timken hub assemblies. Last edited by flnole78 : 04-08-2008 at 11:26 AM. |
Ted's emporium.
We Have Sold Over A Hundred Of Them In The Past Month Or So,havent Had A Return Yet.
eCkO
yeah thats wat i bought the timken..i got the old one off and put the timken on. evrything feels alot better but it might just be me lol. how tight should the three bolts be that hold it? mine came out to 215 after taxes..
Ted's emporium.
I Guess Thats A Good Price,i Paid 144.00 For Mine
Ted's emporium.
Bca,but I Work For A Parts House.so.....
But We Sell Em To The Public For About 215.00 Plus Tax |
J/K ![]() |
Ted's emporium.
lol
Burnt out
ZQ8 Blazer
I bought mine off ebay for $85 shipped, it's a TIMKEN I believe. Still doing good.
They aren't listed, because most people don't know the 2wd Blazers have hub assemblies. Just find the cheapest 4wd hub assembly and email the guy and ask for a quote on a 98+ 2wd Blazers hub assembly. That's what I did. They don't have to be pressed in, you can't repack them. They're very easy to install. |
eCkO
yeah very easy to install. but now i think i need a ignition switch...
94 s10 in progress
must be nice, i had to beat the shit outta mine to get them off the knuckle, and beat the hell outta them to get them off the axle shafts
installation was easy |
ZQ8 Blazer
2wd's don't have axle shafts so it's a little easier
#24 |
eCkO
x2
#25 |
ZQ8 Blazer
Well mine has 1 axle shaft, IT'S CUSTOM!
#26 |
srry to go grave digging, but i think i need a new hub for my front passanger i was just gonna buy them offa the link that was posted above but it seys for 2wd any 1 know where for a 98 jimmy 4wd, thanks guys,
#27 |
ZQ8 Blazer
go to ebay and type in 98 blazer hub. Make sure that it'll fit yours before you buy it.
#28 |
lol damn dude u been helping me out with every thing ima jus start pm you if i got a Q, well hey ha part of ky you from i used to live in franklin, u kno where that is? thanks tho ill go check it out on ebay
#29 |
y eai found 1 for like 68$ thanks a lot
#30 |
1 more Q tho, if ima do 1 side should i just go ahead and do the other side while im working on it?
#31 |
ZQ8 Blazer
I live about a hour and 10 min from Franklin. |
#32 |
lol figs every 1 does u seem to kno a lot bout da trucks, next time im down in franklin ill hafta come by n checkout ya truck my mom lives down there still i go down n da summer to see her so ill hafta let ya kno when im down, but when i was driving home2night i notice this sound from the hub is louder on the driver side but i can feel it more onthe passanger side, u think its just the passenger side thats effd or both maby, like its so loude i can hadly talk to sum 1 if there sitting next to me,
#33 |
ZQ8 Blazer
Most of the time both wouldn't go out at the same time. The noise it makes is kind of a deep hum. I'd just replace the side you know is messed up and if it is still giving you trouble then I'd get the other side, like I said it's not much trouble swapping them out.
#34 |
Be sure that you get the bad one. You can easily identify which side is bad by jacking the tires off the ground and spinning each one. From this it should be obvious which side is bad.
#35 |
when i spin the tire what am i looking for?
#36 |
#37 |
yep its my passanger side, thanks a lot, not i just gotta worder the part
#38 |
Good luck! ![]() |
#39 |
why is it that eery 1 seys its so easy to do ya self but the mech shop wants like 300+ to do it, screw that ill buy a hub off ebay and this onmy own, mech luv to rip people off, atleast at little shady place round me,
