wheel baring?!!?!!?!?!?!??
Old 04-23-2006, 01:02 AM   #1
HotBlaze15
HOTBLAZE15's Avatar
what are the symtoms of a bad wheel baring in a 4wd blazer.....
i hear a whinning coming from the either the left or right front ....its goes up and down in pitch with acceleration...
Old 04-23-2006, 03:47 PM   #2
V8 Member
the_dubster98's Avatar
Re: wheel baring?!!?!!?!?!?!??
yup sounds like a wheel bearing for sure.. im on my second set since buying my 00 jimmy back in 03 it stop if you turn the wheel one way or the other?
Old 04-24-2006, 02:35 AM   #3
Gas drinker
CRAZYASSREDNECK10's Avatar
I got a bad wheel bearing. I can be going down road and it will be whining and i can turn to left slightly and it will quit. Mine sounlds almost like i got the mud grips on my truck.... How hard are these to change??? i am fixing to be putting axle back in my truck and wanna get this changed before i do
Old 04-25-2006, 09:34 AM   #4
If anyone needs a bearing I have a brand new one that I bought and didn't get installed before I traded the truck.
Email me at suds1421 AT yahoo.com if you are interested.
Old 04-27-2006, 12:55 AM   #5
adaman04's Avatar
I think I've got this same thing. How much of a pain in the ass is it to replace wheel bearings on my 99 Jimmy 4x4? Are there inner and outer bearings like on most other rides? What do the parts cost ballpark? Dubster, we fix the same stuff it always seems.
Old 04-27-2006, 05:03 PM   #6
Unregistered User
j894's Avatar
on the 4x4s I think you just replace the whole bearing/hub assembly (with integraded abs sensor),which is sealed/pressed together unit. I think it was around $150 when I was looking to do it, still didnt do it yet though.
Old 05-05-2006, 01:42 AM   #7
BlazinMLew's Avatar
You do replace the entire assembly. It is a very easy fix. A couple of jack stands some sockets and a 3 prong puller and you will be good to go in about an hour and a half.
Old 05-07-2006, 12:51 PM   #8
Canadian Dictatorship
Holeshot's Avatar
It's pretty easy to tell which side it is.
With the front end of the truck jacked up, grab the tire with both hands - one on the top, one on the bottom - and then pull and push back and forth.
Any play at all and you require a new hub bearing assembly.
I've done both sides on my Blazer.
Old 05-13-2006, 02:08 AM   #9
4doorlove
br0v4d4's Avatar
sounds more like you need new ball joints. a wheel bearing wouldnt be THAT loud like mud grip....plus if it was a bearing you would hear is grinding
Old 05-22-2006, 12:33 PM   #10
I did it on my 99 jimmy 4wd
Splitting the ball joints was a bear
Just dont use a impact gun on the new hub or you will screw up teh ABS sensor
Old 05-22-2006, 12:48 PM   #11
Mcfly Minis inc
Mcfly Minis's Avatar
I did my driver side yesterday on my 01' s-10 @ 70,000 miles. Cheapest one I could find was $118 at New Way auto parts. The hardest part was finding a 36mm socket. The rest was cake.
Page generated in 0.57764 seconds with 31 queries
[Output: 73.71 Kb. compressed to 68.89 Kb. by saving 4.83 Kb. (6.55%)]
