curtks10
WHAT IS THIS????Where it goes?
on my 2001 Jimmy,2wd i noticed this layin by break pettal...everything works fine too.i couldnt find any spot for it either
looks like 2 purple wires and 3black ![]() ![]() |
Re: WHAT IS THIS????Where it goes?
I think thats the OBD-II connector so if you wanted to plug a scanner in or something.
NOT OBDII scanner, thats mounted to the dash... see upper left corner of second pic...Thats the OBDII scanner
forum idiot
if nothing is wrong it may be for a option that your truck does not have...
Driving Low
thats what I was thinking
The Dreamsicle
mine doesnt have it connected to anything either. ive heard it's a ground connector or something, like where a bunch of wires meet up.
Grounded 4 Life
Ejection seat option..
Slap my meat on your pita
Thats a limited edition option. Cut the end of the connector off, strip the wires and put them all on your tounge. Let us know your results.
96 4x4 auto jimmy
do you have a factory alarm system.
bellcranks no more
i have that same plug. i heard that it was just a ground bundle
Might be a center consol option for lights.
Pathological customizer
Location: under my hoodz , fixin' teh enginez User is: OffLine |
It's the self destruct plug! Don't cut the red wire, cut the blue one!
Take a Volt/Ohm meter, set it to 100 volts DC,turn the key to the "ON" position. Connect your ground wire to a good ground on the body and take the hot probe and check both pins on the connector. If it has juice it is NOT a ground bundle. If it has juice it should also help you narrow down the search. Not being a smartass but never take word that something is ground. Especially with 2 different color wires. Nothing like blowing up some expensive electronics because you "thought" it was ground. A $10.00 cheapo WallyWorld V/O meter can be your best friend when it comes to wires.
bellcranks no more
100V dc? whyyyyy
It looks like a brake controller / trailer light plug.
