what headlights to buy??
Old 12-20-2007, 01:26 AM   #1
GIT-R-DOWN
JBerry3rd's Avatar
i have a 97 blazer.
i want to replace the headlights in it because they are kinda dim at night.
how do i get to the lights? and it's the top ones i think that are the night driving lights right?
and what number are they
thanks, -Jim
here is a pic
Old 12-20-2007, 03:40 AM   #2
Megabyte
travy's Avatar
Re: what headlights to buy??
Blazer composites. Easiest way would just to take of the grill(8 screws?) then you should be able to reach around the back of the headlights and twist out the bulbs.
Old 12-20-2007, 09:38 AM   #3
Ticket Magnet
Rhotpursuit's Avatar
This is definately not one of the generals better ideas. If The bulbs are not accessable unless you remove the entire headlight. That means you have to remove the battery and airbox.. Of course I figured that out after I installed the housings... I suspose you could remove the housing from the bracket but I have not looked close enough to see if it's possible.
Old 12-20-2007, 09:40 AM   #4
Ticket Magnet
Quote: Originally Posted by JBerry3rd
i have a 97 blazer.
thanks, -Jim
here is a pic
That white grille looks terrible...replace it with a chrome one and send the white one to me and I'll get rid of it for you..
Old 12-20-2007, 02:03 PM   #5
CDN 2WD 2Gen 4-Door!
K Dawg ONE's Avatar
Some Hondas ive worked on are even worse! Gotta take off the headlights on some to get at the bulbs, but, you gotta take the bumper off to get to the bolts at the bottom of the headlights behind the bumper. GAY!
Cavaliers are crappy this way too!
Old 12-20-2007, 07:18 PM   #6
Megabyte
travy's Avatar
On blazers you can't get to the bulbs with out removing the entire headlight housings? wow...
My jimmy I can just pull of grille(real easy) then have easy access to the bulbs behind the housing.
Old 12-20-2007, 10:23 PM   #7
no longer has a 95
95 S_Trucker's Avatar
those are easy to change the bulb in, there are 2 rods sticking up out of each headlight coming through openings in the top of the grill, they might have rubber caps on them, pull the caps off, then get a real small socket(cant remember what size) and unscrew them, then the headlight comes out
i can get some pics to describe what im sayin tomarrow when its light out
highbeam- 9005
lowbeam- 9006
it also says all this in the owners manual.
Old 12-21-2007, 12:06 AM   #8
Ticket Magnet
highbeam- 9005
lowbeam- 9006
Are you talking about the adjusters??
Old 12-21-2007, 12:35 AM   #9
no longer has a 95
no
there to take the headlights off to change the bulbs
ill get some pics tomarrow
Old 12-21-2007, 01:15 AM   #10
Megabyte
travy's Avatar
no
Yeah, you're right about your away. I just forgot to mention it because one of mine is broke and i've never done it that way. i forgot about those though
Old 12-22-2007, 08:41 PM   #11
no longer has a 95
i finally got a pic, i think its a 4 or 5 mm socket, but if you unscrew the rods, the headlight just comes right out.
Old 12-23-2007, 12:44 AM   #12
GIT-R-DOWN
JBerry3rd's Avatar
cool, thanks man
Page generated in 0.58921 seconds with 31 queries
[Output: 82.58 Kb. compressed to 77.36 Kb. by saving 5.22 Kb. (6.33%)]
