Vaccum Problem
Old 08-05-2008, 05:07 PM   #1
Vaccum Problem
There is a loud Hissing sound comming from the back of my Climate control switch. It appears that on our blazers they went to a vaccum control type system but what i can't figure out if if there is a leak or if the hose shouldn't be sucking that much air through it.
Please help
Old 08-05-2008, 06:05 PM   #2
Re: Vaccum Problem
Sorry the hissing sound is comming from the selector switch is what i meant. The Blue line going to it is sucking a lot of air and i am not sure if it is supposed to be or not. Maybe i need a new switch?
Old 08-07-2008, 07:15 PM   #3
Registered Neanderthal
SH-60B's Avatar
Re: Vaccum Problem
It's definately not supposed to be sucking air. A vacuum line may have come off or cracked. You'll need to get at the back of the selector switch to fix it.
Old 08-07-2008, 07:18 PM   #4
Re: Vaccum Problem
the line connection is fine...when i took the switch apart it only makes that hissing noise when the little black rubber piece goes on (the piece that directs the air flow). So i have a feeling its the switch that needs replacing. What i don't know is if its the blue line thats supposed to be the constant vaccum on my year.
Old 08-19-2008, 06:46 AM   #5
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: Vaccum Problem
Mine does the same thing sometimes
Old 08-20-2008, 02:51 PM   #6
SH-60B's Avatar
Re: Vaccum Problem
IDK if it's the blue line or not, but how many "full time" vacuum lines could there be? More than one wouldn't make any sense.
Old 08-20-2008, 02:54 PM   #7
Re: Vaccum Problem
oh well i ordered a new unit and hopefully that solves the problem
Page generated in 0.56707 seconds with 31 queries
[Output: 59.26 Kb. compressed to 55.89 Kb. by saving 3.37 Kb. (5.68%)]
