Troubleshooting 99 Envoy - Rear washer fluid not working
The front washer fluid works properly, but the rear does not.
Anyone have any tips to troubleshoot. Is there a seperate reservoir in the back? Pump location? Ect. |
Re: Troubleshooting 99 Envoy - Rear washer fluid not working
easy EASY fix...it means your starting to get low on fluid...when you get down to about 1/4 left the front will still work but the back will stop...fill up the fluid and it should work
Finished
If its not that the rear pump might not be working.
On the bottle. The reason that the rear pump quits when the fluid gets low is its position on the res bottle. The rear pump is about 2/3 of the way down on the side of the bottle. The front pump is at the bottom on the bottle.
CHANGE YOUR EMAIL ADDRESS
Its your headlights, you need some regular sonoma lights to get it working again. Oh whadda ya know, I have a set I can trade
