Trouble code P0341 help. - S-10 Forum
post #1 of 11 Old 11-18-2011, 01:18 AM Thread Starter
User is: Gumbys10 is offline
Hello and thanks in advance for any help.
I have a 1995 S10 Blazer with a 4.3 Vortec, and I'm getting a P0341 cam sensor code I need help with.
Blazer will run until 188 degrees F and then spit cam sensor code out, it's always 188 degrees when it sets.
I have checked the wiring by doing continuity checks and checking ground, power etc... and all checked ok. I also replaced the cam sensor.
I cleared code with obd II Actron scanner that for some reason links with this obd I compliant system, but my Gen Tech will not link up so I can't get any live stream.
Anyways, I was wondering if anyone knew if the coolant temp sensor could possibly cause this code, or perhaps the ICM ?
BTW I have the late model 95 with the flat dist. cap.
Thanks,
Gumby
Gumbys10 is offline
post #2 of 11 Old 11-18-2011, 01:33 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
Re: Trouble code P0341 help.
You replaced the distributor...correct?
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #3 of 11 Old 11-18-2011, 01:42 AM Thread Starter
Yes, and I double checked that it was on the 6 on dist., and also looked at flat cap to make sure it was pointed at correct point where #1 terminal is, which is across from where the wire is.
Gumbys10 is offline
post #4 of 11 Old 11-18-2011, 01:44 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
Did you make sure your PCM cam adv was + or - 2* from 0
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #5 of 11 Old 11-18-2011, 01:52 AM Thread Starter
It's set I can't adjust it.
Gumbys10 is offline
post #6 of 11 Old 11-18-2011, 01:53 AM Thread Starter
Not sure I understand your VCM cam advance setting question.
Gumbys10 is offline
post #7 of 11 Old 11-18-2011, 10:58 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
You can adjust the CPS, you will need a scanner to do it, and someone/thing to hold the throttle around 1500-2000rpm.
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #8 of 11 Old 11-18-2011, 01:31 PM Thread Starter
I might have to bring it to a shop since I don't have a scanner that will read live data.
Thanks for the help,
Sluggo
Gumbys10 is offline
post #9 of 11 Old 11-18-2011, 02:15 PM Thread Starter
I looked up on setting the timing to plus or minus 1 or 2 from center, and it can't be done on this year Blazer. It has set timing with a roll pin on dist. and can't be moved.
So it looks like I'm back to looking for electromagnetic interferance.
Thanks,
Sluggo
Gumbys10 is offline
post #10 of 11 Old 11-18-2011, 04:22 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
Not timing the distributor. Its adjustment of the CPS.
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #11 of 11 Old 11-18-2011, 04:38 PM Thread Starter
Are you sure ? I have looked at the cam sensor and it looks like it is just set in there, with two small pins to hold it in place in the back, and two screws. There might be some room for movement but not much.
Sorry, I don't mean to question you, but I've been pulling my hair out on this thing for quite some time.
With that little bit of movement, how bad could it affect the running of the engine ?
Sluggo
Gumbys10 is offline
