Towing
Old 09-03-2008, 02:49 PM   #1
Towing
I have a 2002 ZR2 w/ 80,000 MILES ON IT AND i WAS WONDERING IF ANYONE HAS EVER PULLED A 5TH WHEEL WITH ONE? THE WIFE WANTS TO GO CAMPING, BUT WE CANT REALLY AFFORD A FULL SIZE TRUCK AND i HATE TO SELL THE Z, but I have never seen a setup on a small truck, any ideas?? sorry about the caps
Old 09-03-2008, 04:13 PM   #2
Goran's Avatar
Re: Towing
are you serious?
they go 5th wheel cause of weight... you think your ZR2 is that big?
I wouldn't do it if i were you...
power is one thing, but stopping is another...
Safety man, think Safety
Old 09-03-2008, 06:04 PM   #3
o come on
wavrun2000's Avatar
Re: Towing
Yeah i am going to go with no
Old 09-04-2008, 12:16 PM   #4
Registered (Ab) User
Yogi's Avatar
Re: Towing
I think that the 4X4 is rated at 4500# for towing. I'd feel fine with that or real close to it.
Stopping is a matter of good brakes. You would need a good electric set-up and you should be fine.
Old 09-05-2008, 06:51 PM   #5
shifting gears
Re: Towing
You'll be limited to a double axle tag-along with your truck.
I wouldn't even be comfortable with a 5th on a fullsize, unless it was a 3/4 ton with the upgraded rear axle, brakes, cooling, and suspension.
The point of the 5th on a camper is for campers that are so big that wind tends to really sway them. Putting the weight over the back axle and using a pintle helps stabilize them more than a ball hitch. Plus, having it there keeps the trailer from steering the truck when a semi passes you.
Think smaller. 5ths are way cumbersome anyhow. If she needs that much luxury, find a 4 star hotel.
Old 09-05-2008, 06:55 PM   #6
Still fixing the Blazer
joshuaT's Avatar
Re: Towing
I'm thinking he meant to say a caravan/trailer of some sorts and not a 5th wheel. A 5 wheel uses that large towing hitch to attach itself to the bed of full sized trucks. Just wrong words but you can tow a small trailer with no problem.
Page generated in 0.67101 seconds with 31 queries
[Output: 56.12 Kb. compressed to 53.08 Kb. by saving 3.04 Kb. (5.41%)]
