Towing?
I have a 00 Blazer 4x4. I was going to buy a class 3 reciver for it but before I do I wanted to ask you guys. If my blazer is able to handle a trailer/tow dolly with a small car. Thanks
Re: Towing?
I am not sure how acurate this is but i am pretty sure that blazers can tow up to 4000lbs, do a search online i am sure you will find something.
I pee standing
Re: Towing?
or i'm sure the owners manual tells you exactly how much you can tow.
Canadian Dictatorship
Re: Towing?
If you have 3.42's or 3.73's with an A4 and a tow package you will be able to tow 5600lbs.
With a manual trans you are down to 4000lbs with the 3.42's and 4500lbs with the 3.73's. |
Re: Towing?
RATING is 3500 standard i believe, i used to tow an 8000lbs trailer regularly with a airshocks, overload springs no problem....very little sag with the shocks filled and it pulled great
Re: Towing?
i've pulled my '90 Silverado on a car dolly with no problems at all and little sag in the rear end on numerous occasions so a small car would be no problem.. btw i have a 2 door 2 wd
Re: Towing?
Yeah, I know the 2nd gens can tow over 5000 lbs (not very quickly) but they can do it!
![]() I would recommend very highly electric trailer brakes. I have a 5x14 Utility trailer I tow with my Jimmy. It weighs 1150 empty but I often get a ton of rock bringing it to 3150 and it really helps having the trailer brakes! |
Re: Towing?
Get a tranny cooler first
Re: Towing?
5000-5500 lbs is what I've gathered, on a 2nd gen auto.
I definitely agree on the trans-cooler... You need one! Even if you don't tow, I'd recommend it. Brake controller is needed on anything over 3500lbs. Remember you have a short wheelbase, so handeling isn't gonna be so hot with a lot of weight back there... But it'll manage if you get a good brake controller, and drive accordingly. |
