todays adventures
Old 06-25-2006, 12:00 AM   #1
todays adventures
well,
i decided to change the plugs and wires first since i was sure they were the stockers. man was i right. it took alot of bleeding of the hands to get the damn plugs to break loose after 87k plus miles. so after all that was done, the wires for 1 and 3 were swapped to the correct config i went for the oil and filter. i'm not sure when the last owners changed the oil but it was a long time ago. then it was time for a test drive. i also figured i would find out if the 4 wheel drive works properly. so i head to this little place i found on a nonpopulated side of base and went to the hole in the ground i found weeks earlier. throw that puppy in 4 lo and get it locked into place, then i went in one side and up and over the other. then of course i went back the same way. then i tried the other hole. down the hole, up the other side and damn, high centered with nobody around. after trying to rock it back and forth i remembered i was in the desert so i just found a rock and stuffed it underneath the tire that was 2 or 3 inches off the ground. luckily that got me out. then coming home i couldn't figure out how to get the damn thing out of 4 lo. i was thinking i was going to have to ride all the way home doing 25 mph. but luckily i kept trying and finally figured it out. man i wish this thing would've come with an owners manual. but i guess that is how you learn when you're driving your first 4x4 vehicle. feel free to laugh and call me names. just wanted to share.
Superpoo
Page generated in 0.55021 seconds with 31 queries
[Output: 40.85 Kb. compressed to 39.59 Kb. by saving 1.26 Kb. (3.09%)]
