Tire outside VS. Inside
Old 01-02-2006, 10:49 PM   #1
NOT DONE TO MANY PROBLEMS
blazin24's Avatar
My truck orgionally came with the tire rack on the back. When I bought it the rack was off and I didn't have a spare at the time. I bought new tires and have a spare now. I was going to put it inside like you should be able to do (there is a place cut out). The tire won't fit even though the tire is the stock size that is suppose to fit. The alternative is to secure it down flat which takes up all my room. Should i just get another tire rack for outside the truck or try and rig something up inside to make it work? If i got a rack any ideas on how much it would cost? thanks
Old 01-02-2006, 11:16 PM   #2
F1NG3R5UMG1RL5!
Dirt Nasty's Avatar
Re: Tire outside VS. Inside
im going with wrong forum dude..
Old 01-03-2006, 10:57 AM   #3
woof
whitedime's Avatar
id put it on the inside, my 94 has it on the inside
Old 01-03-2006, 07:37 PM   #4
ZR2 member
Scott01's Avatar
My spare wont fit on the inside.
http://www.zr2usa.com/photos/40/07.jpg
Old 01-04-2006, 01:28 AM   #5
adaman04's Avatar
I always thought it looked tough having it on the back. A guy at school has his on top of his Jeep Cherokee. That looks sweet too.
Old 01-08-2006, 02:29 AM   #6
CHANGE YOUR EMAIL ADDRESS
twodoorblazer's Avatar
I hated mine on the back, so I moved it to the inside.... I bought a stock mount with the different jack cover plastic and it worked great. Had to drill two small holes but in the factory location. The divits were already marked under the carpet. This was on my 99 blazer by the way. When I sold my blazer I put it back on the outside to trade it in....
Having it on the inside is great..... you never have to worry about the tire swinging on a decline or slanted parking lot. Never have to open tire to access stuff through glass lift. Once I needed to move a couch, so I just undid the tire from the inside mount, set the tire in the front seat, and slid a 3 cushion couch in the inside resting on the tailgate.... Now with the tire on the outside you coudln't do this. ......
Old 01-08-2006, 02:29 AM   #7
forum idiot
orangesonoma's Avatar
whats a spare tire...
Old 01-08-2006, 02:37 AM   #8
So do you have a stock inside mount already installed and a stock tire doesn't fit??
Old 01-08-2006, 01:47 PM   #9
Vsandme's Avatar
inside? my 4dr has it outside under the back with the spot to shove the back side of the lug nut wrench in to lower the spare...
Old 01-08-2006, 08:32 PM   #10
look at my user name...... the fact he is asking about the mount originally came to be on the outside means he either has a 2 door 2nd gen or a 94 or below 4 or 2door blazer...... I am betting it's a 2door 2nd gen blazer........
Old 01-11-2006, 01:41 AM   #11
It's a Blue thing...
♠ M®. ßlυε ♠'s Avatar
Put that hog on the roof! If you have a roof rack.
Old 01-11-2006, 01:38 PM   #12
chevy42083's Avatar
I don't know why it wouldn't fit inside if it's the stock size. Mine fits.... BARELY but it fits. It is really close, but it is also a hair larger tire size.
Personally, I wish mine was outside, cause I would have more room on the inside. Not very "sporty" looking if that's what you are going for, though.
Old 01-11-2006, 04:51 PM   #13
blazin24's Avatar
my blazer is a 93 2 door 4x4 it origionally had it on the outside, there is a cut out for it inside but the stock tire size won't fit inside the truck. It hits on the plastic piece on the piller by the window. i don't know if there is suppose to be a cut out there or not it even says on the paper in with the jack that that tire size should fit i guess i need a pic of someones blazer like mine 2 door that has it mounted inside to see if that plastic has to be cut my bro has a 96 2 door but that is totally different as far as the mount inside. thanks
Old 01-19-2006, 11:07 PM   #14
If I recall correctly, I remember seeing a few first gen blazers with the tire mounted inside at the junk yard. They all had donuts. Just my observations, i own a 2nd gen.
Old 01-20-2006, 02:25 PM   #15
blazin24's Avatar
How would i do that, i would have to make a custom mount so it isn't just sitting on my roof. And it would probably mess up the air flow too don't need any help making that worse. Also the rubber would probably rot fast because of the sun beating down on it so i would have to get a cover for it tooo.
Old 02-04-2006, 09:41 PM   #16
I have a 87 2 dr blazer and when I bought it, it had a big donut inside I switched to a full size and just put it on the floor in the back. I personally like it better on the outside 1st or 2nd gen. My 95 has it on the outside and my 87 has it in the inside.
Page generated in 0.61273 seconds with 31 queries
[Output: 93.36 Kb. compressed to 86.71 Kb. by saving 6.66 Kb. (7.13%)]
