tailgate problem
Old 06-23-2004, 04:08 PM   #1
low_4wd
Posts: n/a
User is:
tailgate problem
ok on my tailgate when i pull the handle on the inside it doesnt unlock it, so there must be something broken on the inside, only problem is that to take the panel off to see the tailgate needs to be open. so is there anyway to manually unlock or do i have to have the dealer look at it?????
Old 06-24-2004, 05:03 PM   #2
Road Racing Blazer
Daveman2's Avatar
Re: tailgate problem
that's a difficult problem because that's an electric locking mechanisms so if it's not unlocking it's either broken/fuse busted. I'd check to see if it's a fuse, and if not maybe you could try to manually unlock some pliers or something. It can't be that complicated it's just a steel square loop that it hooks into. I dunno im just giving my .02,
I'd try to jimmy(bad pun I kno) it open before going to the stealership, and see if anyone else know if it's a fuse or not.
Old 06-24-2004, 05:09 PM   #3
strip rat
Jimmy-James's Avatar
On my 2-dr, i have a push-in knob on the gate the unlocks and pops-open the glass, and then the gate handle is on the inside. After thinking about it, if my glass is open i don't think my gate is locked at all....i will have to look at that.
Anywho, not sure if you have 4-dr or 2-dr.
Old 06-28-2004, 04:16 PM   #4
Black & Red
Wagn's Avatar
Yeahey. The power lock is just for the window popper, not the tailgate handle. With the doors locked, you can still pull handle from inside and unlatch the tailgate, even though window will still be closed and locked. At least thats the way mine is. If your gate isn't openning, its probably a rod come loose. To open without tearing it up, take the handle off and look for the lever or rod to pull on.
Page generated in 0.55881 seconds with 31 queries
[Output: 50.48 Kb. compressed to 48.14 Kb. by saving 2.33 Kb. (4.63%)]
