Sunroof Drain Hoses
Old 06-24-2007, 12:03 AM   #1
Insert witty title here.
bwhitfield24's Avatar
Sunroof Drain Hoses
Anyone have a link that can show me, or explain to me where the rear sunroof drain hoses are up top, and where they drain at?
2004 Blazer 2 Door.
Old 06-25-2007, 01:22 AM   #2
Re: Sunroof Drain Hoses
uhh drain hoses??? its all sealed...i had a car with a sunroof once..and i never once saw a drain hose
Old 07-01-2007, 10:12 PM   #3
trickedout900's Avatar
they run out to the side of the headliner and then all the way to the back and drain by the tailights. I crushed one of mine in the process of putting my headliner back in ooopps...good thing t=I had to take it all back out. PM me if you need more help
Old 07-01-2007, 10:24 PM   #4
I'm a huge ass
4.3Xtreme's Avatar
Never realized there was such a thing, haha!
Old 07-03-2007, 01:42 AM   #5
neither did i! lol first i've ever heard of them, the only sunroof i had didnt have drain hoses
Old 07-03-2007, 09:57 PM   #6
Thanks. Now I just need to figure out how to take the headliner off....
Old 07-03-2007, 10:00 PM   #7
Negative 10
KENNYMO's Avatar
my oldschool bug had drain hoses running off of its sun roof. they ran rown the side of the car
Old 07-08-2007, 12:10 AM   #8
You have to pull all the plastic out of the way in order to keep from tearing it up, it's a long process but if it's whatyou need it's what you need. Why do you need to get to the hoses may I ask? Are they leaking?
When I first got my blazer the back was always full of water come to find out it was the rear passenger side window.
Old 07-19-2007, 11:34 PM   #9
Dranko's Avatar
I know on my '99 bravada they drain right on top of my front door hinges im going to have to take care of that
Old 07-20-2007, 04:41 PM   #10
From my understanding there is a drain in each corner. 1 or both of my rear ones is clogged and needs to be cleaned out so that water wont gather in that tray. both rear windows were replaced and it is still happening if i am not parking the right way (where the nose is pointed downhill)
Old 07-20-2007, 04:42 PM   #11
Those are the front drains, from my understanding there is a drain in each coner of the tray. See above post
Old 08-07-2007, 10:34 AM   #12
Goran's Avatar
that is the stupidest thing i have ever seen... i don't think they could have aimed it any worse... WTF was GM thinking???
I have the same situation on my 00 Envoy
RETARDS
Old 08-09-2007, 02:35 AM   #13
Dranko's Avatar
Its helps to sell more parts just good business right? At first I thought it couldn't be true it must be a breather of some kind but no
Old 08-09-2007, 09:26 PM   #14
If I ever find the tweed I'm looking for I will clear these drain hoses when I do the headliner.
Old 08-13-2007, 06:14 AM   #15
Dranko's Avatar
found this
Old 08-13-2007, 07:44 AM   #16
you can remove the sunroof trim that goes around the headliner, and pull the headliner down enough to peek in with a flash light and see the hoses. best bet is to take some compressed air and blow through the lines, and reconnect, 9/10 times they're clogged up with some crap
Old 08-13-2007, 12:40 PM   #17
found this
Thanks a TON. That is exactly what I am looking for!
Old 08-24-2007, 10:15 PM   #18
Banned
HotRodV6's Avatar
if you drop the rear tailgate, and take a look at each corner of the tailgate by the corner of the taillight, you will see a little hose sticking out that is kinda flat with a slit in the middle of it, and when you sqeeze it the slit opens up, there is one on each side and these are the rear sunroof drains, just take an air hose and with the sunroof open blow back up the hose with light pressure first, and see if it blows anything out, id go ahead and do all 4 hoses.
alot easier than dropping the headliner.
Old 08-30-2007, 10:42 AM   #19
I don't want to blow it back up in there.... I need to figure out how to suck it out. Maybe tape the end of my shop vac to the end of the hoses?
Old 08-30-2007, 11:32 AM   #20
I still watch cartoons!
zoideraserb's Avatar
but if you blow it out you can clean it out from the top side... i would think
Page generated in 0.61067 seconds with 32 queries
[Output: 107.40 Kb. compressed to 99.27 Kb. by saving 8.13 Kb. (7.57%)]
