Canadian Dictatorship
Strange Road Noise......
There is some odd road noise happening to my Blazer.
When driving straight, it's there all the time......if am turning right - it get's louder........if I'm turning left it goes away entirely. At first I thought it was worn tires......I had Yokohama Geolander AT+2's on until recently. They vibrated and shook the truck badly. I bought some new BF All Terrains day before yesterday to get rid of the problem. It's still there though......not a bad as before but still present all the same. As long as I am turning left the road noise goes away. I've asked around and the general concensus seems to be the bearings.......what do you think? If that is so - what am I looking at for a fix? Are the bearings and the hub one unit? I'm only - so so - mechanically..........and I've certinally never done something like that before.......is this something a backyard mechanic can do without an incredible amount of difficulty? Thanks for your replies..... ![]() |
Insane Network Engineer
Re: Strange Road Noise......
Bad right hub bearing,,, Replace them both for even wear...
does the noise get louder as you go slower or faster?
Hub bearings eh? Something I could do myself with no previous knowledge? Or something best left up to pros? How much are the parts? |
ZR2 member
Here's a good write up on changing them.
http://forum.zr2.com/ubb/noncgi/ulti...c;f=3;t=002320 |
the hub replacement is not very difficult but all the ones i have changed on cars and trucks the noise gets louder as you get rolling quicker
Picked up a used hub assembly out of a 02' Jimmy for $100 (canadian) and put it in.
No more noise. ![]() Thanks for your help everyone. |
V8 Member
yupp.. wheel bearing.. typical it seems for four wheel drives in the s-series,.. or so the dealership told me when i had to take the jimmy in..
No, GM wanted $489 for a new hub bearing. Six months warrenty on parts, one year on work (at $110 a hour!)
Local car parts wholesalers wanted $299 and that is with my 30% government employee discount. Six months on parts. So a used one was well worth it. The 02 Jimmy I pulled it out of had 41000 km on it. |
Didn't realize you were in canada...
that price sounds right for a GM oem replacement hub in canada
i have the same thing where the noise gets louder as i go faster and it gets quiet as i slow down...i need to replace the hubs?
V8 Member
yuppers.. they get really bad if you go over a bump and the truck "floats over the bump?
Heh same problem here, mine was alignement...alot of vibration, I had some over camber in the fd tire odly
Just replaced both hubs on my Jimmy over the weekend. I really wasn't having any major noise issues and the old ones didn't really look that bad but I feel better knowing they're new!
Hope you torqued the center nut to the right specs!
103 ft/lbs just like the GM manual said! |
I bought mine off Ebay from a guy that bought them for his 4x4 S-10 and then sold the truck. I only paid $103 each for them. ![]() They were brand new in the Box GM parts. |
