Stock HID headlights
Old 02-27-2005, 07:19 PM   #1
I have the stock HIDs in my 2000 Jimmy Diamond Edition, i need to replace one of them, is it a dealor only part, the guy at advance auto looked at me wierd and tried to sell me a Silverstar as a replacement.
Old 02-27-2005, 07:23 PM   #2
forum idiot
orangesonoma's Avatar
Re: Stock HID headlights
you need a d2r or a d2s bulb...dealer is gonna charge you a crazy amout of money... look on ebay...
Old 02-27-2005, 07:30 PM   #3
are both of those bulbs the same, and i was afraid that this wasn't going to be cheap
Old 02-27-2005, 07:38 PM   #4
forum idiot
no one is for reflective housings and the other is for projection...im sure you have D2R bulbs...most dealers get 100 bucks per bulb....are you sure its the bulb and not the ballest?
oh and dont mess with the plugs or anything connected to them when they are on...the high voltage they put out will knock you on your ass...i know i have been there before...
Old 02-27-2005, 07:42 PM   #5
Would this work
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7956781305&fromMakeTra ck=true
How would i check if its the bulb or ballast? The other morning driving to work, it flickered a few times and then went out completely.
Old 02-27-2005, 07:42 PM   #6
Polishing Guru
samandjen1's Avatar
Envoy's have a D2S bulb. You will have to go to GM and buy the bulb it has a special plug. You may have to buy 2 on account GM changed their bulb color after 2000 so your bulbs color and look wont match.
Old 02-27-2005, 07:44 PM   #7
forum idiot
Quote: Originally Posted by 2000_Diamond
Would this work
yes thats what you need...
what i would do is swap the bulbs...if it starts to work on the other side and not the other side...you know its the bulbs...if not check power to the ballast
Old 02-27-2005, 07:46 PM   #8
Polishing Guru
samandjen1's Avatar
http://www.gmpartsdirect.com
sells them for $149.00 + shipping for each side
Parts numbers-16526491
Thats for the Left or Right
Old 02-27-2005, 07:46 PM   #9
forum idiot
damn screw that...ebay!
damn im gonna start selling my hid bulbs i have around the shop...150 plus shipping...DAMN
Old 02-27-2005, 07:46 PM   #10
Polishing Guru
samandjen1's Avatar
nope
Old 02-27-2005, 07:48 PM   #11
Polishing Guru
samandjen1's Avatar
Would this work
Do not use a D2R
to check bulb pull the headlight you will see if the bulb is bad.
Old 02-27-2005, 07:48 PM   #12
forum idiot
nope
why nope? the only diff between the two is that little gray stipe on the one...i could never tell the diff...plugs are the same...
Old 02-27-2005, 07:50 PM   #13
The Philips number on the outside on mine is 16526104, i took the 2 screws off the big silver box which i am guessing is the ballast, i couldn't figure out how to get the bulb itself out, there were another 2 screws in there, do i need to loosen those or does the bulb pop right out.
Old 02-27-2005, 07:50 PM   #14
forum idiot
Do not use a D2R
and sam...i have installed a lot of hid kits and i have had to repair plenty...it is hard to tell if the bulb is bad or not....there is no filament to look at...
Old 02-27-2005, 07:51 PM   #15
Polishing Guru
samandjen1's Avatar
very very hard to find a GM HID bulb on Ebay. GM's bulbs have a special bracket and plug harness that plug into the GM ballast
Old 02-27-2005, 07:52 PM   #16
Polishing Guru
samandjen1's Avatar
glass should turn whiteish, from what i have seen
Old 02-27-2005, 07:53 PM   #17
forum idiot
from what i have seen...all D2S and D2R bulbs have the same base and connector....got any pics...
Old 02-27-2005, 07:53 PM   #18
Polishing Guru
samandjen1's Avatar
yes, but dont touch the bulbs glass just incase its good
Old 02-27-2005, 07:53 PM   #19
forum idiot
that does not mean a bad bulb in most cases...i have seen them with white glass and they work fine....
Old 02-27-2005, 07:55 PM   #20
Polishing Guru
samandjen1's Avatar
its not the base its the shield around the glass, the envoy headlights have a built in sheild so they use a D2S(no metal sheild around the bulbs light output. D2R have a sheild for headlights that dont come with built in sheilds
Old 02-27-2005, 07:55 PM   #21
forum idiot
yeah dont touch the bulb!!
Old 02-27-2005, 07:57 PM   #22
forum idiot
are you talkin about that little gray stripe on the bulb?
Old 02-27-2005, 07:58 PM   #23
If i get the bulb out and get pics, would you be able to figure out if its bad? Awaiting massive snow storm here for the next 2 days, so it won't happen for a few days.
Old 02-27-2005, 07:59 PM   #24
forum idiot
not really i have seen bulbs work that were smoked whit on the glass..andi have seen them with a orangeish color to them...and they all worked fine...
Old 02-27-2005, 07:59 PM   #25
Polishing Guru
samandjen1's Avatar
here is a GM set up
Old 02-27-2005, 08:00 PM   #26
forum idiot
but im talkin about the bulb...that is just the starter that attaches to the bulb/ housing...the bulbs should all be the same...
Old 02-27-2005, 08:01 PM   #27
here is a GM set up
Don't think mine quite looks like that, can i upload pics here, give me a few minutes to run out and take some
Old 02-27-2005, 08:01 PM   #28
Polishing Guru
samandjen1's Avatar
http://img.s10forum.com/album536/adu.jpg
Old 02-27-2005, 08:02 PM   #29
Polishing Guru
samandjen1's Avatar
D2S
http://img.s10forum.com/album536/adv.jpg
Old 02-27-2005, 08:03 PM   #30
Polishing Guru
samandjen1's Avatar
D2R
http://img.s10forum.com/album536/adw.jpg
Old 02-27-2005, 08:04 PM   #31
forum idiot
yeah no shit.. and .the D2R has a little grayish stripe on the bulb
D2S on the right and D2R on the left...
Old 02-27-2005, 08:14 PM   #32
Polishing Guru
samandjen1's Avatar
ya, and Envoys use a D2S
http://img.s10forum.com/album536/abw.jpg
Old 02-27-2005, 08:16 PM   #33
forum idiot
ehh...like i said in the start of this...i said i was not sure ahat bulb it was...so them bulbs on ebay are the right ones....he just has them listed wrong...
Old 02-27-2005, 08:19 PM   #34
Here are pics of mine, if it matters at this point, sorry about the size of the pics, i hope you guys have broadband.
http://mysite.verizon.net/edjohnston...eadlight/1.jpg
http://mysite.verizon.net/edjohnston...eadlight/2.jpg
http://mysite.verizon.net/edjohnston...eadlight/3.jpg
Just tell me which one i need to order and the cheapest place to get them.
Old 02-27-2005, 08:23 PM   #35
Polishing Guru
samandjen1's Avatar
you need to buy them from Gm or Gmpartsdirect.com
Old 02-27-2005, 09:49 PM   #36
Would these work, 150 a side from gmpartsdirect is a little outrageous
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33710&item=7957845 106&rd=1&ssPageName=WDVW
Also what temp is stock gm bulbs in case i only get one.
On a side note, anyway to turn off the day time running lights so these bulbs last a little longer.
Old 02-27-2005, 09:56 PM   #37
Polishing Guru
samandjen1's Avatar
sorry , you have to buy GM on account of the plug. But can you pull or twist the bulb out of the silver box where its mounted? un bolt it and take a pic.
DRL can be disabled by pulling the fuse in the under the hood fuse box.
GMs are 4200-4300K
Old 02-27-2005, 10:07 PM   #38
forum idiot
yes you can thats what i have been saying...the bulb should twist out of the silver box...
Old 02-27-2005, 10:14 PM   #39
Polishing Guru
samandjen1's Avatar
you should have said it eariler!
Old 02-27-2005, 10:16 PM   #40
forum idiot
lol
Old 02-27-2005, 10:27 PM   #41
i tried twisting it earlier but wasn't sure if that was it, if its not snowing too badly tomorrow i will get it out and take a pic.
Thank you for the info for the DRL, i see no reason to have them turned on during the day
Thank you both for all your help, whatever happened to the days when a headlight was 5 bucks and took 5 minutes to change.
Old 02-27-2005, 10:29 PM   #42
forum idiot
haha...they still do ...but you got the diamond edition...lol
Old 02-27-2005, 10:30 PM   #43
forum idiot
do yo have the fog lights? if you do you may need to modify the relay under the hood for the drl...
http://www.s10forum.com/forum/f62/ahl-and-drl-how-tos-34645/
^^^ check that out...
Old 02-27-2005, 10:37 PM   #44
i have the fog lights in the brush guard, would that mod disable the automatic lights from turning on when its dark?
Old 02-27-2005, 10:42 PM   #45
forum idiot
if you modify the pin on the relay you will lose nothing but the drl's
Old 02-28-2005, 05:58 PM   #46
SteveI's Avatar
Damn, I'm glad my Diamond Edition doesn't have the HIDs! Awful expensive!
Steve
Old 03-01-2005, 08:56 PM   #47
forum idiot
well today i remembered that the hid's out of a lincoln mark 8 have the hid bulb built into the starter box...they suck...
Old 03-05-2005, 02:05 PM   #48
ok i can't get the stupid bulb out, it doesn't want to turn or just slide out, i have to be missing something here.
Old 03-05-2005, 02:35 PM   #49
ok a quick update, i really got this fokked up, some of the plastic broke off, i think it might end up at the dealer to get this one done
Old 03-05-2005, 03:57 PM   #50
ok i am begining to think that the bulb is not going to come out, could this be a one piece where everything needs replaced.
I called the dealorship here and they tried to sell me the 14.95 bulb and tried to tell me that GM never used HIDs
Page generated in 0.69692 seconds with 31 queries
[Output: 211.99 Kb. compressed to 193.30 Kb. by saving 18.69 Kb. (8.82%)]
