Speaker Installation HELP!
Old 09-05-2007, 01:02 PM   #1
so I have all 4 front speakers insatalled in my 98 blazer however I cannot figure out how to get the rear panels off to get to the speakers....any help?
Old 09-05-2007, 01:39 PM   #2
badSol's Avatar
Re: Speaker Installation HELP!
Just have to take out the screw on the plate by the door handle, then pop that little plate inside the armrest and remove the 2 screws in there, then pull and you're set (that's assuming I remember correctly from when I did mine, but I believe it to be correct)
Old 09-05-2007, 01:48 PM   #3
I should clarify i have a two door so like its one solid panel
Old 09-15-2007, 04:38 AM   #4
BanginJimmy's Avatar
you have to pull the grab handle off, then pull the upper seat belt bolt. That will give you enough clearance to replace it. It wont be fun, but it is doable. Thats how I did mine.
Old 09-15-2007, 12:38 PM   #5
The Dreamsicle
cpolaris502's Avatar
yah its a pain. take off both of the handles back there, the one in front of the small window and the one above it, it will make it easier. then pull down the side of the piece that goes across the top in the rear. have the window open so the panel doesnt get caught on that lever.
Page generated in 0.57179 seconds with 31 queries
[Output: 52.64 Kb. compressed to 49.96 Kb. by saving 2.67 Kb. (5.08%)]
