Something leaking under my Blazer
'04 4dr 4wd Blazer. Something is leaking (steady drip) under my truck. It appears to be coming from the center of the drivers door. Touched my finger to it and it doesn't appear to be dark, green or oily and no smell that I can sense which only leaves w/w fluid I think. My rear washer hasn't worked since I bought the truck a few months ago. Does the rear washer fluid line run anywhere around this area? All engine fluids that I can check (oil, tranny, coolant, etc) seem to be at normal levels and the truck isn't running hot. If it's not the rear w/w fluid, what could it be? How difficult is it to change out (or repair) the w/w fluid line (assuming that's what it is)?
Re: Something leaking under my Blazer
Under the drivers door is where the fuel filter is along with the other fuel lines. I thought the rear washer line ran inside the vehicle, but I might be wrong.
I guess it could be fuel but touched my finger to it and it didn't smell like fuel. Hmmm...
