Roll Pan
Old 01-28-2008, 02:48 PM   #1
I Need to Post More
RANDOMIZM's Avatar
Question Roll Pan
This is probably a repost... but i couldn't find info anywhere...
Is the S10 rear lower Bed Panel peices a direct fit for the blazer to put on a roll pan??? Is the length correct... or will it extend past the rear tailgate???
Old 01-28-2008, 03:23 PM   #2
CDN 2WD 2Gen 4-Door!
K Dawg ONE's Avatar
Re: Roll Pan
Of a fleetside box, yes.
However, you will have to weld them on.
And, your likely thinking, hey, ill use a fleetside rollpan! Well, the pan is straight and doesnt match up with the 'bow' in the blazer tailgate.
If you search over on blazinlow.com there a member who did just this. It has pics aswell and he says, much more worth it to just buy a step shaver!
Old 02-04-2008, 11:55 AM   #3
BanginJimmy's Avatar
Re: Roll Pan
s-10 rear lower corners are different length than a blazer. A blazer is about 4-5 inches shorter than s-10. To use s-10 bedsides you will have to section them, then weld them abck up.
Page generated in 0.55702 seconds with 31 queries
[Output: 47.22 Kb. compressed to 45.23 Kb. by saving 1.99 Kb. (4.21%)]
