Rim question
I just bought some 18in rims for my 2003 blazer, and i was told that i might need a spacer for them to fit. The lug pattern is the same, but the offset is +56mm, im not sure what the offset on the blazer is, and im in iraq, so i cant go check it out on my blazer... can anyone help?? Do i even need spacers, and if so, what size?
Re: Rim question
well, if its a 4wd then no you won't need spacers because the offset is high, but if its 2wd then probably |
Re: Rim question
Its a 2wd, any idea on what size spacer?
Re: Rim question
you will need a 2.25" spacer.
Re: Rim question
Front and back or just front?
Re: Rim question
These rims are corvette c6 rims b.t.w. I will be posting pick of blazer from the time i got it to what it is now... as soon as i get back from iraq.
Re: Rim question
front and back
Re: Rim question
Thanks for the help man!
Ill be home from iraq in about a month and i can finally install everything and get some good pics up here. Will a 2.25 in spacer make my rims come out past the wheel well? Cause i want to slam it... |
Re: Rim question
no, a 2.25" spacer should put the wheel in the same place as stock on a 2wd.
AcrophobiA
Location: Tuscaloosa, AL; Ft Stewart, GA User is: OffLine |
Re: Rim question
Yep get those spacers and you will be set! Where are you stationed at?
Re: Rim question
Im over at Fob Hammer, Iraq right now, but im stationed in Ft. Benning, Ga. With 3rd brigade 3rd infantry division. Do any of you guys know where i can get these spacers? Ive been looking but im guessing that im looking in the wrong place, cause i cant find anything.. Thanks for the help!
Re: Rim question
check the classifieds section or even ebay. i found a pair on ebay not to long ago
AcrophobiA
Re: Rim question
Ebay man! Ft Stewart, GA 1st BDE 3ID here man! Granted I just got here, but anyways, yeah ebay.
AcrophobiA
Re: Rim question
Here are some 2.5" spacers should get you were you want to be. This auction is only for 2 spacers.
Re: Rim question
Thanks for the info man, i just purchased them, ill be home in about a month to put my black vette rims on my blazer... its gunna be nice when im done.
Registered (Ab) User
Re: Rim question
Many thanks to you guys who serve our country so well under such harsh conditions! Thank you!!
