Replacing the Turn Signal Lever switch - S-10 Forum
post #1 of 8 Old 07-06-2010, 06:13 PM Thread Starter
hyenad's Avatar
User is: hyenad is offline
Question Replacing the Turn Signal Lever switch
Hi guys I have a 2001 chevy blazer and the windshield wipers don't work. The switch that is between the cruise control and the the wiper fluid control just keeps spinning around. Do I need to replace the entire Turn Signal Lever switch or is their a way to fix the wiper switch?
hyenad is offline
post #2 of 8 Old 07-06-2010, 09:36 PM Thread Starter
hyenad's Avatar
Re: Replacing the Turn Signal Lever switch
Now the windshield wipers won't stop. I pulled the fuse and that stopped it for now.
hyenad is offline
post #3 of 8 Old 07-06-2010, 09:47 PM
Registered Hoosier
Hoosier Rick's Avatar
Yes' you need to replace the whole switch.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #4 of 8 Old 07-07-2010, 12:17 AM Thread Starter
hyenad's Avatar
Do I need to tear down the entire column to change it out?
hyenad is offline
post #5 of 8 Old 08-20-2010, 06:13 AM
User is: kurtdaniel is offline
Looked at the wiring diagram and it looks like the fast setting runs straight to the relay module. All the other signals run through the general module then through the relay module to the wiper relay. There is only one wiper relay.
Check the general module and then the relay module.
post #6 of 8 Old 08-21-2010, 05:23 AM
Hi guys I have a 2001 chevy blazer and the windshield wipers don't work. The switch that is between the cruise control and the the wiper fluid control just keeps spinning around. Do I need to replace the entire Turn Signal assembly switch or is their a way to fix the wiper switch?
i bet, You will need to replace the wiper control module. good luck,,hope this helps..
post #7 of 8 Old 08-21-2010, 12:32 PM
GM
GM's Avatar
User is: GM is offline
Send a message via AIM to GM
Sounds like you need to replace the entire combo switch.
It's a bit tricky but fairly easy. If you've got a manual read up on it first. It will save you 30 mins of head scratching.
GM is offline
post #8 of 8 Old 08-24-2010, 12:27 AM
S-clusive ohio pres.
snoplow's Avatar
User is: snoplow is offline
Send a message via AIM to snoplow Send a message via MSN to snoplow Send a message via Yahoo to snoplow
1.pull the wheel
2. remove column cover
3. remove the lower plastics
4. there is a big connector held togehter with a 7mm bolt that is the harness for the multi function switch.
5. the connector comes into 3 pieces thers tabs to separate the sides of it from the main body.
6. theres 3 t-15 or so torx bolts holding the multi function switch on.
7. remove the mess and go get a new one or a replacement my local pul-a-part sells em for 15
i got 3 but there for a 95-97 or id hook ya up.
8.profit
snoplow is offline
