replacing the fuel filter on a 99 Balzer 2WD
Old 09-02-2008, 12:32 PM   #1
I purchased a new fuel filter and wanted to cange it this weekend. First do I need any special tools for this and 2nd how difficult is it?? I located it on the inside of the frame rail on the drivers side. Thanks in advance for any help. Bob
Old 09-02-2008, 01:06 PM   #2
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: replacing the fuel filter on a 99 Balzer 2WD
Been about a year since I changed mine, but lets see if I can remember I may be getting some of this confused with my fullsize. You'll need 2 wrenches to undo the back side, one to unscrew the filter and the other to hold it in place and not bend the lines. At the front there are two plastic clips you just squeeze and pull the filter out, be sure to have a rag wrapped around the filter unless you like gas on you. Put the new on back in in the reverse order. It's VERY easy to do.
Old 09-02-2008, 01:35 PM   #3
chevy42083's Avatar
If you DON'T like gas spraying all over you...
Start the truck, and pull the fuel pump fuse. The truck will drain the the pressure from the fuel lines, and die. Then all you get is dribbles down your arms into your arm-pits.
To fix that, tie a rag around each wrist
Old 09-02-2008, 01:52 PM   #4
where's my chippy?
lee-mill's Avatar
make sure you use flare nut wrench to limit the chance of it stripping as well
Old 09-03-2008, 11:48 AM   #5
Great ideas,thanks for all the tips. I will pull the fuse and run the gas line dry. I am not fond of a gas shower,especially at 365 a gallon.
Old 09-03-2008, 01:27 PM   #6
I piss excellence
Kaznlilgreenmen's Avatar
I used a pair of wide jaw pliers to push the filter out aswell...I live in Ny so rust is just another part of a vehicle...but put one end on the plastic ring the filter slides into and the other side on the filter and press it out.
Old 09-04-2008, 03:13 PM   #7
Still fixing the Blazer
joshuaT's Avatar
I used 2 cresent wrenches. I did it in my driveway and got sparyed with fuel. Talk about a golden shower. Good think I don't smoke. I think it made a big difference in my trucks fuel intake. How often should you change them? I changed it at 140,000 miles and got 20,000 on the new one.
Old 09-04-2008, 04:10 PM   #8
The Dreamsicle
cpolaris502's Avatar
As far as i know, mine is stock too at 143k miles. I am getting awesome mileage and full pressure so i wonder if theres any reason to replace mine?
Old 09-04-2008, 05:12 PM   #9
Registered (Ab) User
Yogi's Avatar
GM quit putting them on. Just the "sock" in the tank on new vehicles.
Old 09-04-2008, 07:25 PM   #10
chevy42083's Avatar
Personally, I'd say change it. No idea when it needs to be changed... but 143k sounds like plenty.... btw, it's cheap insurance against something else that COULD go bad .
Old 09-04-2008, 07:38 PM   #11
ZQ8 Blazer
ZQ8 Blazer's Avatar
I forget how often your suppose to change them... For as much as they cost and as easy as they are to change, I'd just do it.
Old 09-11-2008, 01:06 AM   #12
Moderator
Wicked Mayhem's Avatar
i did mine cause i put a new pump in.. mine looked fine. but for 10 dollars, why not? only 68k on the blaze though..plus i feel better knowing its got a nice new filter on it
Old 09-11-2008, 12:52 PM   #13
ZQ8 Blazer
ZQ8 Blazer's Avatar
$10, man you got ripped a new one, I gave $9 for mine
Page generated in 0.57979 seconds with 31 queries
[Output: 80.75 Kb. compressed to 75.22 Kb. by saving 5.53 Kb. (6.85%)]
