Removing stock A/C
Got my HotRod Air in and I'm staring at a firewall right now...
What can I remove? There is a HUGE wiring mess from the over-complicated GPS head unit, alarm... and I think the A/C is responsible for a lot of the mess Anyone have any pictures/info on what wires I can maybe cut and tape off? Just for cleanliness and shit. Also, I am (so far) unsuccessful at removing the big black box in the center of the firewall, where the duct gets it's air from. Also on the front of it is a small box with wires going to it... not sure if it's a part of the A/C system? |
Re: Removing stock A/C
Got a few pics: ![]() Small box, wire harnesses go into the left side, do I need to keep it and the wires? The big box... haven't found a way to remove it, maybe I didn't look hard enough... or maybe I should just use the dremel? ![]() This was mounted onto the box I removed... wondering if I need it? Looks like a relay for something |
Anyone?
Anyone?
Anyone?
Also, to remove the blower box, will I have to take apart the whole damn front end? |
Slap my meat on your pita
No idea, but sell me your compressor.
That last pic looks like the relay for the blinkers. If you dont have that in the blinkers wont work.
The Dreamsicle
youd probly have better luck in the bagging section. pretty much everything from the back of the doors forward is identical in any s series.
I got it all figured out... the big black box has bolts on the outer firewall
