Removing roof rack holes
Old 12-20-2005, 01:44 PM   #1
I have read that welding is the best move my grandpa is a welder so im going to ask him what he can do for me. As for the little ring under the screw, how do i flat that down? I have to flat it down then weld right? THen after im done welding what do i do?
Thanks guys, i really like this forum.
Old 12-21-2005, 08:38 PM   #2
Vsandme's Avatar
Re: Removing roof rack holes
ugh...you removed the roof rack :-\ id say tape behind and bondo? i never took my rack off to know what the holes look like...if they are small i dont think welding would be necessary...how are you painting over? and wont you still have the strips down the center of your roof? or are you removing them as well?
Old 12-22-2005, 12:24 AM   #3
I'm probably drunk.
BLAZ1N's Avatar
there are little nubs that stick up where it screws down
take your headliner off and take a look from that side
Old 12-25-2005, 11:59 AM   #4
By Vin# only I Guess
STILL4WD's Avatar
never bondo over holes! weld them up....dont know if you can pop those out but either grind them down or drill them out, then weld
Old 12-25-2005, 12:02 PM   #5
Give me 3 yrs...
JollyRojer's Avatar
im going out and grinding mine down right now
Old 01-11-2006, 01:45 PM   #6
chevy42083's Avatar
I've heard of the uber cheap way.... rubber caps to plug the hole.
Using a flush top screw with teflon tape to seal it, and just leaving it flush with the roof.
Seen billet caps that screw into place and leave a nice "finished", but not "shaved" look. Just a nice trim peice I guess.
Heard of the flush screws with teflon, then bondo the SMALL amount of a hole left.
There are some options. Just know the correct way is to grind or somehow lower the raise, then weld and paint. Although, not reversible like the other options.
Old 01-31-2006, 08:46 PM   #7
Red Dog's Blazer
Chris's_96Blazer's Avatar
do you have any idea where to find those billet screws? i also wanted to remove my rack, I did but I took out the middle slats then put it back on the truck cause the screws sticking up were ugly. thanks
Old 03-31-2006, 12:45 AM   #8
anyody know the thread size?
Old 03-31-2006, 02:19 AM   #9
Insane Bowties
Insane 95 Blazer's Avatar
Welded mine shut with the headliner out just had a friend cut out some little circles from 16 gauge . Weld slow and make sur not to get it to hot . The roof would probably look really stupid without its ribs . I think its for support of the roof . However I eventually would like to have a rag top and thats the only way I would remove those ribs.
95 Blazer 4 Dr 4/4 drop Shaved Handles Antenna , Roof Rack Holes and Rear Wiper
Epoxy Black paint . Pics Soon
Old 04-19-2006, 07:20 PM   #10
CHANGE YOUR EMAIL ADDRESS
dragginblaze's Avatar
when u undo the bolts theres little nipple things sticking up like 1/16" maybe, all u need to do is fill the holes iin with a welder and then grind it down and smooth it out, no biggie.
Old 05-08-2006, 01:34 AM   #11
when i took mine out i cut away some of the rubber sealent used to hold it in place then put the screws back in so i could pull out the ring part that the screws go into and now your able to weld over the holes
Old 05-23-2006, 05:59 AM   #12
~V.C~ NJ- DA PREZ
blazinfnestyle's Avatar
if the roof rack isnt there, you really dont need those ribs up there either. there are support beams inside under the headliner and if you were to sawzall your whole roof and put a ragtop in, then you would be depending on the frame of the ragtop. i wanna do mine eventually too but its the least of my problems rite now
Old 05-23-2006, 06:17 AM   #13
roadlet_411's Avatar
i was wanting to get one of my buddies to weld them and grind it down, but I'm afraid of the headliner catching fire. Too lazy to remove it, i guess... lol
Old 05-24-2006, 09:23 PM   #14
under construction
miniblazer's Avatar
dude i sanded mine down, and used fiber glass. i havent had any problems with it.
Page generated in 0.58408 seconds with 31 queries
[Output: 84.32 Kb. compressed to 78.44 Kb. by saving 5.88 Kb. (6.97%)]
