removing mud shield?
Old 08-04-2008, 04:23 PM   #1
on the 4wd Jimmy there is a plastic shield on the bottom/front with an access port for the oil filter. The wife will be the one driving this most of the time and aside for a snowstorm I don't ever see this being used off road. Just seems to be a total PIA to try and work on this thing with that shield in place. Is this shield really necessary and is there any reason to keep it on there?
Old 08-04-2008, 04:25 PM   #2
Has Training Wheels
beaniebmx's Avatar
Re: removing mud shield?
on mine it says to leave the door closed for engine bay cooling.
also works as a bay gaurd and wind blocker
Old 08-04-2008, 04:31 PM   #3
no longer has a 95
95 S_Trucker's Avatar
what do you have to work on so often that its in the way? if you do have to take it off, its only 6 bolts, takes 2 minutes to take it off.
Old 08-04-2008, 05:35 PM   #4
I'm going to need to do front end steering work, do oil changes, and replace the oil lines in the near future. Obviously I will not be doing all that in one day. Oh, and it's a complete PIA to change the belt with it in place. If I don't need it, it makes no sense to keep it there. (is it keeping the CV shafts from rusting or something?)
Old 08-04-2008, 06:20 PM   #5
no longer has a 95
it probably wouldnt affect much, maybe the engine temp would rise a little from less cooling, but its only 6 bolts. if you can do susp and steering work and replace the oil cooler lines you can put 6 bolts back in.
Old 08-04-2008, 07:49 PM   #6
Overhead Console Expert
raven2510's Avatar
yes...it protects the oil filter, bottom of crank pully from shit on the road hitting it. dont remove it
Old 08-04-2008, 08:03 PM   #7
forum idiot
orangesonoma's Avatar
i dont have one...maybe it runs a little hot on really long drives and really hot days..180-190 ish
mine has not been there and i take mine off-road..
Page generated in 0.57444 seconds with 31 queries
[Output: 59.43 Kb. compressed to 56.05 Kb. by saving 3.38 Kb. (5.69%)]
