Removing gas tank cover on 2 door questions.
Old 08-23-2007, 06:48 PM   #1
blazinb2000
b_evans06's Avatar
Can I take off just the black plastic cover over the gas tank on my 2000 2dr blazer? I want to leave the tank but remove the cover to clean it. Does it have separate bolts or use the same as the tank?
Old 08-23-2007, 07:46 PM   #2
BanginJimmy's Avatar
Re: Removing gas tank cover on 2 door questions.
I believe the bolts for the cover are seperate. take a look under the truck and see for yourself.
Old 08-23-2007, 08:15 PM   #3
blazinb2000
b_evans06's Avatar
I have looked under the back and I can see the bolts. I can't see the bolts for the actual gas tank unless their above the mounts for the cover or they are the same. I do not want to take out a couple of bolts and the gas tank start to come out. Just thought I would try to get an answer on here so I would know what I am getting into.
Old 08-23-2007, 10:27 PM   #4
there are straps holding the actual tank up, the bolts are just holding the cover.
Old 08-23-2007, 11:30 PM   #5
blazinb2000
b_evans06's Avatar
Thanks for the help man.
Page generated in 0.55894 seconds with 31 queries
[Output: 53.02 Kb. compressed to 50.32 Kb. by saving 2.70 Kb. (5.09%)]
