Removing Badges
Old 05-07-2007, 10:48 AM   #1
It's 4:20 Somewhere!
SmokeeJay's Avatar
Question Removing Badges
I would like to remove the Blazer badges from my truck. I have a few questions:
1. Are they decals or will there be holes in the body once I remove them?
2. Is a hair dryer going to get hot enough to allow me to pull them off?
3. Once off, what is the best way to remove any residue?
I checked in the how to section but did not see anything on this.
thanks,
J.
Old 05-07-2007, 12:51 PM   #2
SmokeeJay's Avatar
Re: Removing Badges
i did a more extensive search and found a thread on removing the badges. thank you anyways.
Old 05-12-2007, 10:08 PM   #3
pat-izzle's Avatar
Re: Removing Badges
well i kno u found a thread.. but in case anyone cant:
I removed the chevrolet emblem off the tailgate pretty easily..
All the 2nd gens (im pretty sure) are just stick on decals with that black foam glue backing stuff.
So get a shop towel thats clean, a screwdriver, and carefully use ur rag and a hand as a lever n pry it off in pieces..
You can try to use this stuff called "gue be gone" or sumthin.. I used 3M's sticker/residue remover.. Be sure to test it out on ur truck to see if it will remove ur paint or not tho.
I did mine but it took sum time.. I'm sure the whole screwdriver bit is a real bad idea!! But luckily i didnt touch mine at all...
Old 05-13-2007, 02:50 PM   #4
midwest SS's Avatar
Re: Removing Badges
i use welders wire at work for removing emblems..
Old 05-13-2007, 07:47 PM   #5
SmokeeJay's Avatar
Re: Removing Badges
I just finished taking all the emblems off. I used fishing string, my fingernails, and some adhesive remover. Takes a little bit of time, but looks so much better.
Old 05-16-2007, 11:05 PM   #6
pat-izzle's Avatar
Re: Removing Badges
Nice
Old 05-17-2007, 11:27 PM   #7
Red Dog's Blazer
Chris's_96Blazer's Avatar
Re: Removing Badges
I just took ALLL my trim off today, already done away with the emblems on back a long long time ago.
the back trim pieces only ones that had holes from the screws that held it on.
Old 05-20-2007, 02:10 AM   #8
Blazin 4 life
Eurogoldls's Avatar
Re: Removing Badges
Try this page for help on removing badges:
Emblems
Page generated in 0.61741 seconds with 31 queries
[Output: 63.24 Kb. compressed to 59.47 Kb. by saving 3.77 Kb. (5.96%)]
