Rear Sway Bar End Links 2 Door 95+?
Old 01-13-2008, 01:50 AM   #1
Moderator
Wicked Mayhem's Avatar
my blazer is an 02.. i guess 95+ 2 doors will be the same.. ive lengthened my sway bar end links and not sure exactly how much cause they slid into a pipe so im wanting to shorten them so can put my sway bar back on and want to know the length of them from the eyelet hole they mount to the frame to the end of the endlink
thankssssssss
Old 01-13-2008, 02:37 AM   #2
bellcranks no more
greencactus3's Avatar
Re: Rear Sway Bar End Links 2 Door 95+?
you want the endlinks the length thats just right to keep the swaybar 'parallel' to the ground, or as close to that as you can. being dropped, id assume you need shorter than stock
Page generated in 0.56374 seconds with 31 queries
[Output: 43.61 Kb. compressed to 41.98 Kb. by saving 1.63 Kb. (3.74%)]
