Rear hatch unlocks but doesn't pop.
I just bought this S10 ZR2, so I'm not familiar with it yet. On my Gen-I, when I hit the hatch release, the hatch pops open a smidge and I can lift it. On my Gen II, it doesn't pop. When I get around to the back after using the button, the hatch is locked. I can hear it pop when I hit the button.
There's a closed sticky where a guy asks the same question as I need answered, but he didn't get an answer. I'm guessing this is not a normal behavior. What I'd like to know is whether I should be picking up a new activation mechanism while the going is still "good" for unlatching it. Secondarily, while I'm on this topic, someone has replaced the key activation with a button activation which I view as a bit of a security risk. I bought a key-activated one at the wrecker so does anyone know who to call to get it re-keyed and about how much that would cost? If this was answered in another thread, please redirect me. I ran a search on spring liftgate hatch mechanism and a bunch of other stuff and couldn't find anything pertinent except for the aforementioned question in the sticky. Thanks |
Re: Rear hatch unlocks but doesn't pop.
BTW: It's a 99.
forum idiot
you should just pm me your questions..you can adjust the tension on the latch..its 2 10mm bolts
mine did the same thing...you pop it and you hear the motor but when you get back there its locked...you can adjust it or there is a small pusher (pin switch) that might be missing or broken Last edited by orangesonoma : 02-15-2009 at 06:48 PM. |
CDN 2WD 2Gen 4-Door!
Also, IIRC, key-pop is on the split gates (pre-98) and push-pop is liftgate (98+) so it may not work how you want it....
forum idiot
nope...all three of my blazer the glass pops
95 tail gate...glass pops. 98 lift gate...glass pops. 02 tail gate...glass pops. all three whether it was push button on dash or push or turn key in gate would pop the glass |
OrangeSonoma knows all. If I PM'd you all these Q's, I wouldn't be able to come back in two years time and see what the heck it was that I was supposed to do to fix XYZZY.
Is there a "how to" for adjusting the tension? It's not in my Haynes and my search of the site turned up nada. |
forum idiot
well i know when mine did that it was to tight...so you have to remove the rear cover and there are two 10mm bolts that hols the latch in..a pivot and the adjuster....bring the latch closer to the back of the truck just a bit and see if it gets better...also check to see if that pin switch still has spring to it..
i have pics of what it should look like if you want |
Pics would be fabulous. Yes, please! I'm heading up to the local pick-n-pull for a sender for an '89 S10 tomorrow as well as a '99 sunroof and a remote oil filter block and .... you get the picture. I think they're starting to recognize me there.
Right now, when the glass lands in lands _really_ heavily. I just replaced the lift supports too. |
forum idiot
shitty pic but you see that bolt...that is the bolt that slides in the oval hole and below that is a the pivot one..
![]() this one is of the pin switch pusher that pops the glass up.. ![]() sorry for the shitty pics but its at night with my cell phone and a led flash light |
just for shits and giggles since i didnt wanna ask this int he sticky.... is it possible to repalce my lift gate with a tailgate on my 00 jimmy 4dr... i know the 2drs jimmy had that option but i dont know about the 4dr... i go to alot of tailgating events and wanna be able to sit down... that and im use to having a tailgate anyways.. i feel like a soccer mom everytime i go to open it..lol
forum idiot
my 95 has a tail gate and everything mounts different..i think you are screwed
thats kinda what i figured but it dont hurt to ask.... maybe if it ever gets rear ended ill convert it over but its already seen one pretty bad accident so i dont think it can take another
hate to highjack this but ohh great orangesonoma, how can i fix mine so it will stay shut. my problem is oposite, window wont close and lock in. mine is a 95 bastid blazer, lol. thanks and sorry for the highjack.
matt |
forum idiot
cool thanks
