rear end swap
1997 Blazer 4x4, AC, V6 4.3
my pinion seal went, brought it to the shop, there was severe damage to the inside requires a rebuild. now, i have a rear end from a 1995 S10, probably 4.10 gears, what does the process involve to swap in a 4.10 rear end in this blazer? Is it just a straight bolt in? or do I have to change the driveshaft etc. |
ZQ8 Blazer
Re: rear end swap
If it's like my fullsize was then it'll bolt right up unless one rearend is a 2wd and the other is a 4wd. I'd go get a 98+ Blazer rear end.
Re: rear end swap
If your is a 4x4, you need a 4x4. The 2wd are narrower. Drive shaft will bolt up.
ZQ8 Blazer
Re: rear end swap
Re: rear end swap
thanks, I have a 2wd rear end spare, i guess I will look for a replacement rear end 4x4
Re: rear end swap
would the 1st generation rear axle and differential work? I found a cheap 1993 rear
ZQ8 Blazer
Re: rear end swap
I am pretty sure it would, might want to ask on the general suspension section.
Re: rear end swap
![]() Doesn't the gearing have to remain the same because of the transfer case? otherwise the front and rears wont turn at the same time? they'll be working against each other, rather then with each other... |
Re: rear end swap
wow, yours looks bad lol mine wasn't that bad, it still drives
i found a rear end from a 1995 so hopefully i can pick that up soon |
