Rear brake calipers sticking ?
Old 01-31-2009, 06:06 PM   #1
Got a 2001 Blazer thats having problems with the rear brakes. The brake pads are wearing unevenly so I think its the calipers that are the problem. I replaced the rotors and pads, and disconnected the parking brake to see if that was causing it. Then tried starting the car while it was up on stands and found that the drivers side rear wheel is stuck!
Wut da problem iz?
Here are some pictures of the drivers side rotor and pads that might help.
http://s509.photobucket.com/albums/s332/visithtang/
Old 01-31-2009, 09:53 PM   #2
Giggity Giggity
Woody22's Avatar
Re: Rear brake calipers sticking ?
how many miles on the truck?
Old 01-31-2009, 10:10 PM   #3
Zeeke98's Avatar
Replace the calipers. Having the same issue with mine. I just need to get time and money to get them replaced. It would help if it warmed up too. Sucks freezing my ass off while changing brakes!
Old 01-31-2009, 11:19 PM   #4
bling bling like WHOA
xtreme03blzr's Avatar
Make sure it's not just the pins that are frozen, might be able to get away with just the braket and new pins.. much cheaper then the caliper
Old 01-31-2009, 11:42 PM   #5
Zeeke98's Avatar
Sliders were fine on mine. Seals are cracked and let crud get into the piston causing it to stick.
Old 02-01-2009, 02:51 PM   #6
Giggity Giggity
Woody22's Avatar
ya after so many miles they are shit. i learned that the hard way with my s10
Old 02-01-2009, 04:51 PM   #7
The sliders looked fine, but I couldn't get the piston back in. Tried bleeding the caliper and the fluid came out swamp water green! Going to flush the system and buy new rear calipers for now.
Old 02-02-2009, 02:58 AM   #8
ZQ8 Blazer
ZQ8 Blazer's Avatar
Mine had the same problem so I cleaned and greased the pins(or maybe what you guys are calling the sliders.)
Old 02-02-2009, 02:51 PM   #9
Also had that problem on an 01 and the damn pins were screwed up. It was almost like the inside of the caliper where the pins were supposed to slide was corroded out and caused the pins to bind. We hit the pins with a wire wheel and used some brake grease and all was well again.
Old 02-02-2009, 02:57 PM   #10
Good Bye SonomaST
91sonomast's Avatar
its a fairly common problem with these things, the rear caliper pistons seize on em, just replace the caliper, i think they're 10-30 bux depending on where you get them. mine did it about 3 weeks after i bought it.
Old 02-02-2009, 09:58 PM   #11
Zeeke98's Avatar
Where the hell you finding rear calipers for 10-30? Try $60-100 depending on if they have the bracket and hardware and pads.
Old 02-02-2009, 11:16 PM   #12
ZQ8 Blazer
ZQ8 Blazer's Avatar
Junk yard?
Old 02-02-2009, 11:18 PM   #13
Zeeke98's Avatar
Yeah...so you can get another pair of junk sticking calipers?
Old 02-02-2009, 11:19 PM   #14
ZQ8 Blazer
ZQ8 Blazer's Avatar
Yeah, but they're such a good deal!
Old 02-04-2009, 11:04 AM   #15
Calvin51's Avatar
While your replacing them, if you have an automatic, get rid of the e-brake shoes. Nothing but trouble. BTW...replacing calipers....get new. It will save a lot of headaches on down the road.
Old 02-04-2009, 11:22 AM   #16
yeah there are certain thinks you dont get from a junkyard... brakes are a major one... if your trucks are bad what makes you think the junk yard ones are any better....
Old 02-04-2009, 10:33 PM   #17
Good Bye SonomaST
91sonomast's Avatar
price have gone up a little since i bought mine 6 months ago, it was 39.xx bux with tax, link to otterzone reman caliper(where and what i got)
http://www.autozone.com/R,3422873/ve...ductDetail.htm
and loaded calipers with brackets(that was without cores) were about 250-300 for the pair(bought a set for my sonoma when i did blazer rear axle)
Page generated in 0.59092 seconds with 31 queries
[Output: 92.50 Kb. compressed to 85.53 Kb. by saving 6.96 Kb. (7.53%)]
