Lurker
question on jimmy shep shaver
I tried searching but couldn't find a definate answer but i have a 98 jimmy with the body molding and wanted a roll pan. It's a four door, so my question is are the two door and the four door the same? if not what ones do i use? thanks
Re: question on jimmy shep shaver
its the same.
The Dreamsicle
Yep, same.
Lurker
thanks that helps me out. no i just need to put that info to use
Lurker
ok one more thing if my jimmy has the silver part on it, where would i get those step shavers from. here is an example:
i don't think normal blazer ones come up as high as those. and they are all one piece |
![]() Me want! but can not find ![]() |
Lurker
that sucks because if you can't find it Doug then i'm probalay sol. u seem to find everything on the internet machine
The Dreamsicle
That looks like a RAW fiberglass rollpan for xtreme blazers. You're talking about the part that goes up along the wheel well? that is there to match with the xtreme fender flares. If you are talking about the trim that runs horizontal, that is not part of the step shaver.
You can find that rollpan at www.itsraw.com but it is pretty expensive. Last edited by cpolaris502 : 12-04-2008 at 07:49 PM. |
blazer is dunnnnnnnnn!
yea, that looks alot like my RAW pan, but it's not the exact same. im guessing someone used a RAW one, and modified it a little
heres some pics: ![]() ![]() ![]() ![]() Last edited by purplepassion : 12-04-2008 at 07:54 PM. |
