Question about shaved door handles?
Old 09-16-2009, 12:45 AM   #1
Question Question about shaved door handles?
My question is Can you shave the back doors on the 4 doors and make them work by remote aswell?
Second Question Can You add a Auxiliary solenoid to the front drivers door lock in case u lock yourself out?
Old 09-16-2009, 02:24 AM   #2
juggalotim's Avatar
Re: Question about shaved door handles?
Yep u can shave the rear doors. Auxiliary solenoid? eh not really needed. Just install a hidden button. If ur really worried install 2 of em for dif doors just incase the selenoid craps out. And with the hidden button i used a water proof one wire directly to the selenoid so if my battery died and i needed to get in the truck to change the battery i could just hook up 12 volts to the button wires that go straight to the selenoid and pop i'm in. I have even seen some people have a wire to pull on to get in. I'd def buy the AVS ones since they just bolt right up. Most use a cable and is PITA fixing the cable if they break... You have to rip your door panel off and then unlach ur door with ur hands. With a blazer atleast you also have the hatch to pop open if none of the doors work for some reason.
Old 09-16-2009, 11:24 AM   #3
I can't see shaving the front doors without shaving the rear doors too.
Old 09-16-2009, 02:15 PM   #4
Juggalotim Thx for the quick response on the second question is where is the best place to install the hidden buttons?
Sammy what Are you talking about? the doors where getting shaved ether way but i read on another web site that they could not get the rear doors to pop by remote.
Old 09-16-2009, 02:37 PM   #5
juggalotim's Avatar
on my old truck there was a hole in the frame and it was like a perfect fit didn't even have to drill. Don't do it in like the fender wells cause most people put them there i have heard. Just make sure its not visable and don't tell many people about it.
Old 09-16-2009, 03:10 PM   #6
Site Sponsor
Adam@Autoloc's Avatar
I wouldn't bother with backup BUTTONS or WIRES. Just get an emergency release cable.
We are working on the bolt in rear door poppers right now. Should be ready within 2 weeks.
Old 09-16-2009, 06:43 PM   #7
I misunderstood your question. I thought you were wondering if you could shave the rear door handles.
Page generated in 1.43982 seconds with 31 queries
[Output: 60.96 Kb. compressed to 57.60 Kb. by saving 3.36 Kb. (5.52%)]
