pulling a trailer w/ 96' 4.3 blazer??
Old 01-12-2006, 11:19 AM   #1
idragbodys10's Avatar
is a 96' 4.3 blazer able to pull a trailer with a s10 on it??...around 100-200 miles a few times a year?
Old 01-12-2006, 11:26 AM   #2
Rollin` Proud on 15's
Eight433's Avatar
Re: pulling a trailer w/ 96' 4.3 blazer??
i definatly wouldent... the blazer doesent weigh enough to safely tow a vehicle roughly its own size, plus the trailer. Brakes on the trailer will help, but if the trailer starts to wag like a dogs tail (on a bridge, in the wind, when you pass a semi, etc) may god be with you. A tow dolly would probably be your best option.
Old 01-12-2006, 10:27 PM   #3
Vsandme's Avatar
i disagree...well sort of...good points, dont mean to sound rude...but i pull an 8000lbs box trailer occasionally from work...brakes are a must...i do have alittle suspension work done on the jimmy though to carry more weight, but i dont have any problems really...though it will do alot of wear and tear to your suspension, brakes, and if the engine strains too much, you can wear it down and possibly blow it...but just an s10 i dont think youd have too many problems
Old 01-13-2006, 03:03 AM   #4
Eight433's Avatar
very true.
however notice i said i WOULDENT, not COULDENT.
although i'm not one to take chances with this sort of thing. I'd rather have too much vehicle and never need it than not have enough when you do need it.
although a couple months ago i did pull a sunfire with my 2.2 5 speed reg cab.... cheaper than a wrecker
http://memimage.cardomain.net/member...66_91_full.jpg
Old 01-13-2006, 07:40 AM   #5
Insane Network Engineer
rlith's Avatar
Didn't have a prob doing it myself... Just remember to keep it in 3rd the entire time (not OD) And a tranny cooler would be a bonus...
Old 01-13-2006, 11:42 AM   #6
V8 Member
the_dubster98's Avatar
my 00 jimmy pulled my 94 on a uhual tandem axle with no problem.. but the stock suspension saggs wayy to much.. nothing some helper springs wont cure thou... but had plenty of power for the hills of rhode island
but a car dolly would be better
Old 01-13-2006, 12:31 PM   #7
Eight433's Avatar
tow dollies are cheap too. i've been looking around and even ones with brakes only run around 8-900 bucks. hmmmmm...
Old 01-13-2006, 03:38 PM   #8
Vsandme's Avatar
i have about a 1/4inch drop in the rear with the 8000lbs trailer :-) <3 airshocks and overload springs :-D but alas that is coming to an end with the drop shocks and blocks i wont have the weight capacity in the back :-( but ill save them for use in my next s-series :-D
Old 01-13-2006, 05:12 PM   #9
chevy42083's Avatar
Since no one has said... 2dr or 4dr?
2dr = hell no
4dr = stated above... tow dolly better, brakes better,
Old 01-13-2006, 05:14 PM   #10
4 door..
Old 01-13-2006, 06:32 PM   #11
Banned
Blazin810's Avatar
How about a 2-door 4.3L towing a 10 foot enclosed?
Old 01-14-2006, 11:20 AM   #12
Vsandme's Avatar
chevy24083.....a single cab can, i own a single cab beat around 4cyl 1996 and ive towed a 1g awd talon with it ;-) and gmchigh, a honda civic can pull a 10' enclosed trailer empty, you need to specify how heavy it is ;-)
Old 01-14-2006, 06:12 PM   #13
chevy42083's Avatar
I meant if the Blazer is 2dr, then I wouldn't try to tow a pickup with it. The truck itself is longer than the blazer, so the trailer and all would be WAY too much.
A 4dr blazer has alot more weight and length to it than a 2dr.... so I would feel MUCH safer with a 4dr tow vehicle.
Old 01-15-2006, 03:17 PM   #14
Banned
Blazin810's Avatar
I got no clue. It's just a Featherlite 10FT enclosed carrying 2 dirtbikes. I'm sure I can do it.
Old 01-15-2006, 04:19 PM   #15
Vsandme's Avatar
gmc, easily...you could do that with a baseline 5spd 4cyl s10
Old 01-15-2006, 05:42 PM   #16
Banned
Blazin810's Avatar
I know, I love asking stupid questions...
Old 01-16-2006, 09:44 PM   #17
what about a bagged blazer?
Old 01-17-2006, 02:10 PM   #18
Vsandme's Avatar
what about a bagged blazer? i wouldnt tow WITH it, or do you mean towing it?
Old 01-18-2006, 02:28 PM   #19
chevy42083's Avatar
Depends on the bag setup. Certain ones wouldn't be suitable for towing... others would be better than stock.
Old 01-18-2006, 03:29 PM   #20
Playin in the mud
kacy's Avatar
I towed a tandem axel trailer with a 90 eagle talon on it with no brakes fo like 70 miles it sagged the rear suspension even with the trailer loaded level.The truck has the power to pull it but it was probably to much weight ...
Old 01-19-2006, 07:13 PM   #21
Aaron
2 B NVED's Avatar
I've got a 2001 4 door 2 wheel drive, I tow a 4x8 trailer with 5 bicycles on it and I really wouldn't tow anything more than that. Actually, i probably would but...........
Old 01-20-2006, 11:35 AM   #22
Vsandme's Avatar
yeah stock suspension isnt much...i have a 2.5" lift when i fill the airshocks and to pull that 8000lbs trailer i have to fill them, but i do stay level ride height with it
Page generated in 1.42381 seconds with 31 queries
[Output: 111.53 Kb. compressed to 102.73 Kb. by saving 8.80 Kb. (7.89%)]
