Minnesota Man
power seat fix!
I have noticed alot of blazers and bravadas have had a problem with power seat quit working.
well after it quit working in mine no one seemed to know why... I replaced the motors for it ,the breakers ,and the switch.. How to .... pull the carpet back under the driver feet area and there should be a wire harness running in the middle of the feet area with a black housing.Open the housing and you should see 3 orange wires crimped to just one orange wire. If your seat didn't work you will probably see alot of corrosion around where the 4 wires connect. If it is you need to cut them up and rewire them using new but connectors and this should fix it. hope this helps someone else ![]() |
