The Bowtie Brigade
Power locks won't work on inside?
Anybody else had this problem? Its a 2000 4dr Blazer. My key fob locks and unlocks fine. But, it won't do anything from inside. The button for the hatch does nothing too. I checked the fuse, and it was fine. Any help would be great.
Re: Power locks won't work on inside?
I would look for a loose/bad connection or broken wire feeding the switches in the door. The rear glass is another circuit, bad switch? Use the wiring diagrams below to help track it down.
BTW, these diagrams are for a 95 so they may not be exact but should be similar enough to help track things down. Wiring Diagram of power door lock/remote entry part 1 Wiring Diagram of power door lock/remote entry part 2 Last edited by pacawallop : 04-15-2007 at 12:20 AM. Reason: added caveate |
Are all the inside switches not working?
The Bowtie Brigade
None of the inside switches work.
hates 4cyl s10s
im having the same problem.......power windows and all work just not the power lock buttons.....help.
Blazen SS
hey, i just got my blazer 2 weeks ago. i fixed most of what was wrong but i can't figure out the passenger rear doors power lock and unlock doesn't work.
The Bowtie Brigade
My power windows work fine too. Still haven't figured out what is wrong with the locks...
Gettin it together
i had the same problem on my 2000 2dr blazer it turns out the wiring harness in my truck fried. *** something with the tailgate release button shorting out *** but all was good since it was still under warranty.
The Bowtie Brigade
^^I'm def gonna check into that...^^
