Popping sound from my front end...HELP
Old 01-14-2009, 10:35 PM   #1
BlazerBeater
wgraves's Avatar
Well This has been going on since I've owned the blazer. Sometimes when I back up, hit a divot in the road, turn the wheel,ect. theres a popping sound from the front end. I can hear it and feel it do this. My Blazer is a 1996 4dr 4x4. No lift or anything, just stock height. Replaced Ball joints last year and it didn't do anything. Can't seem to find out where it's coming from! Any help would be great. Thanks
Old 01-14-2009, 10:42 PM   #2
Blue-X
yz85608's Avatar
Re: Popping sound from my front end...HELP
is it a loud pop, or subtle sp?
does it happen everytime you turn your wheel?
Old 01-14-2009, 10:44 PM   #3
BlazerBeater
wgraves's Avatar
Its not very loud, just enough to hear it and it doesn't happen every time.
Old 01-14-2009, 10:56 PM   #4
check your cv axles & sway bar links
Old 01-17-2009, 07:36 PM   #5
juggalotim's Avatar
might be one of your torsion bar mount bushings(if the 96s even came with them?) My 90 4x4 s10 i replaced the drivers side one like twice the 3 years i owned it and never really went off roading. Every time i would turn or hit a bump u would hear and feel a popping from underneath.
Old 01-17-2009, 09:00 PM   #6
Calvin51's Avatar
Check your hood bolt where it goes through the hinge
Old 01-17-2009, 10:27 PM   #7
bmxbang's Avatar
mine does that 2 sometimes but i just figured it was one of my lower balljoints because its shot...
Old 01-25-2009, 12:32 AM   #8
Blazer_1997's Avatar
I have a bushing out on my upper arm, causing it to do it.
Old 01-25-2009, 03:18 AM   #9
AWD V8's Avatar
Also check that the adjusting nuts for the upper control arms are tight. Put a wrench on them to check, they need to be be real tight. If they are not tight it will clunk when you turn into a corner hard or when backing up and turning the wheel when you hit the brakes.
Old 01-27-2009, 04:39 PM   #10
Calvin51's Avatar
Also end link bushings or shock rubbers if not bagged.
Page generated in 0.56972 seconds with 31 queries
[Output: 69.40 Kb. compressed to 64.93 Kb. by saving 4.48 Kb. (6.45%)]
