S-Dime Swag
plastic blazer gas tank
i was lookiing at this blazer that was up on a lift a work, and it had a stock plastic gas tank? did they come with them? or is it after market, i didnt know that the s10/blazer seris even had that? if so how much liter is it over the steel? what year did they come on? (i dont know the exact year but it s a 99 and up) i needs info please
thanks |
Re: plastic blazer gas tank
are you looking at the gas tank itself or the gas tank shield? im pretty sure the stock tanks are steel and the tank shields are a hard plastic.
03+(possibly mid 02+) have plastic tanks. S-10 and Blazers.
My '99 has a plastic tank. But then it's a Japanese Blazer.
S-Dime Swag
idk i didnt get a second look at it to get more info
but it def look like it WAS NOT a shell which leaves me to believe that it is one piece plastic tank does anyone know if they came like that or was a upgraded option? |
If it helps, I understand all Blazers GM exported to Japan had plastic tanks as standard. Can't confirm which was supplied in the US though.
I told you.
My 03 and 04 blazer both had plastic. I have worked on two 03 s-10 both plastic. |
my 00 jimmy has a 18 gallon plastic tank from the factory... i only know this cause it fell on my head when i was replacing the fuel pump a few months back... lol.. i filled three 5 gallon gas jugs with the gas that was in it and i still had plenty of gas in there...
if you wanna replace your metal on you are lookin at atleast 800 bucks cause the sending units are different as well.. ad also the tanks arent cheap... i was gonna pick up a new one and the dealer wanted 700 bucks alone... |
S-Dime Swag
so what years did they come on? was it only blazers? it sucks they have a different fuel pump sending unit
i think it was only 99+ blazers.. george had a metal one and i beleive his was a 98... i can give you my vin and you could cross reference the parts at the dealership to find what your looking for... ill pm it to you in a sec...
S-Dime Swag
thanks for the pm
i work at a chevy dealer, so if i give him the vin he could tell me the pump it needs right? (for the plastic) |
forum idiot
my white blazer is a 98 and it has a plastic tank..
DRTY DYM
my 98 and 2000 s10s both had plastic tanks. my 95 jimmy has a steel one
S-Dime Swag
so would it be an option?
The Dreamsicle
Mine's a 99 2dr and its steel.
it may vary state by state possibly... who knows why they did it... maybe its part of the factory tow package or something... its GM.. they do alot of goofy things... kinda like why do i have zr2 torsion bars when i have a gmc jimmy... or the fact that for right hand drive vehicles they make them with a e-brake lever instead of a pedal... i am trying to track down a part number for that setup... i want it so bad... .hahaha
S-Dime Swag
i know gm does some stuff different
is there a certain number or letter on the vin for it? or would it be a rpo thing? i just didnt know that they existed |
Founding member of DA
i think the 4 doors are plastic and the 2 door is steel i have the stock one from my 02 blazer just sitting with a sending unit in it wouldnt be able to ship it though
Slap my meat on your pita
My 98 originally came with a steel tank, but I swapped it for a plastic one because my metal one got dented up.
wow... the rear wiper and hatch switch is on there as well... if at all possible kiwi would you be able to get me a part number for the console and lever... i already have the console shifter... i think your placement is the same as mine....
Part numbers are impossible. These trucks came from Japan & we have no source for "new" parts here in New Zealand. I've tried to find a Chevy dealer in Japan with no luck.
If we need parts we get used ones from the Chevy specialist (no chevy dealers in NZ) They import used trucks from Japan & strip them to get parts. They also buy wrecks from insurance companies. The only way I would think is for you to check with a GM dealer in the States & maybe quote the vin number from a RHD truck. If it helps you can quote my vin no. 1GNDT13W9XK118620. I have a spare console & brake lever but it'll cost an arm & a leg to get it to you. |
S-Dime Swag
im going to do a fuel cell in the back of my truck when i get the v8
i just saw one at work (plastic tank on a blaze) and wanted to get some infor on it thanks alot guys |
#24 |
thanx man im goonna be lookin into that in a little while... soon as the kiddies go down for a nap... its impossible to have a conversation without them asleep.. haha
#25 |
S-Dime Swag
thats what they are for right? haha
#26 |
Road Racing Blazer
Weird news! I never knew they used plastic tanks, my 4X4 had a plastic shield on it and it's definitely a metal tank about 19 1/2 gal I think.
98 2dr |
#27 |
S-Dime Swag
i guess there is steel, steel with plastic shield, and a full plastic one
#28 |
It's interesting to note that the steel tanks had a plastic shield & the plastic tanks have a steel shield!
#29 |
Nope I have not seen a steel shield on a blazer?
#30 |
S-Dime Swag
maybe your imported blazers kiwi
#31 |
I'm amazed that GM did not build ALL Blazers the same - even for export.
I can understand the LHD vs RHD but ..... Oddly, I'd have also expected to find your gas tanks on the other side too. (your passenger side). |
#32 |
S-Dime Swag
how did you get this japan blazer
