Passenger Door Weather stripping ??
Old 01-08-2009, 10:18 AM   #1
Goran's Avatar
Passenger Door howls with the wind while driving down the road?
any ideas? i'm thinking it's the weatherstripping...
how hard is that to change?
Old 01-11-2009, 02:07 PM   #2
Calvin51's Avatar
Re: Passenger Door Weather stripping ??
Door Hinge pins and bushings. It's letting the door drop slightly and not letting it seal tight when it's shut. Put new ones in and it will pull the door tight to your seals. Took me about 30 minutes per door with a few minutes of my wife helping me on each door to get the pins back in. Advanced Auto has new ones in the HELP section. Common problem with the Blazers/Jimmy's.
Old 01-11-2009, 02:11 PM   #3
Wannabe Dragger
ExtCab96S_Dime's Avatar
Yup, mine's doing it too. Leaks water and wind lol.
Old 01-20-2009, 04:49 AM   #4
duglas911's Avatar
The weather stripping is easy to change out. We swapped out the drivers side front and back doors in less than 10 mins. The top part is seperate from the opening around the door..make sure you get that piece also..it actually has some sticky tape on it..the big O part around the inside of the door just fits into a track. We got our at LMC truck. Plan on doing the passenger side and back this spring.
Old 01-20-2009, 02:33 PM   #5
Goran's Avatar
great step by step instructions with pics for changing the pins/bushings
http://www.bodyshopzone.com/archives...replace_1.html
Old 01-21-2009, 02:14 PM   #6
Goran's Avatar
Worked like a charm...
The Envoy is nice and quiet now...
just need to get a spring compressor to put the hold open spring back...
Old 03-27-2009, 02:18 PM   #7
WalkGood's Avatar
What do you do if the holes in the bracket for the pin have worn out of shape and are now oblong (oval or egg-shaped)??
Old 03-27-2009, 07:15 PM   #8
2 choices, 1 either put the oversize bushing kit in, or buy the replacement hinges, then you will have to drill the welds out of the old ones, and separate the body panels to put the new ones in.
Old 03-27-2009, 09:40 PM   #9
WalkGood's Avatar
How big is the oversized bushing? Does it use the original sized pins?
Page generated in 0.58385 seconds with 31 queries
[Output: 66.96 Kb. compressed to 62.84 Kb. by saving 4.13 Kb. (6.16%)]
