oxygen sensor location
Old 12-20-2007, 12:29 PM   #1
where is the oxygen sensor located on a 2000 gmc jimmy ?
Old 12-20-2007, 12:35 PM   #2
User Registered
Re: oxygen sensor location
i could be wrong but it beleive it to be just after the cat.
Old 12-20-2007, 12:36 PM   #3
do you know if there is only one?
she is running real rough.
Old 12-20-2007, 12:41 PM   #4
User Registered
yea. mine is an s10 and i changed it awhile back and it helped out a little but there are many other things that can equate to it running rough. first off i'd changed oxygen sensor(o2 sensor) it is actually expensive if i remember correctly. this will cut down the other things causing the rough idle or running.
Old 12-20-2007, 02:54 PM   #5
well I notice that it did fine until the temp came up. then noticed that the temp never cam down. I just flushed the radiator last night and replaced the the thermostat . there is a lot of rusty water in the radiator again today. I think I will have to spend the 200 for the radiator. it might not be the sensor.
Old 12-20-2007, 03:15 PM   #6
'98 2.2L S10 Owner
Well, I know in a S10 there are two o2 sensors. The one after the cat does not effect fuel / air, but the one before the cat does.
The one after the cat only tells you if your cat is working properly.
Old 12-28-2007, 04:54 AM   #7
insomniac
With my 96, I had 4 O2 sensors. 1 each on the left and right just after the exhaust manifolds. 1 pre- catalytic convertor, and 1 after the cat.
This of course is with the 4.3 v6. I would assume this is the same for the 00's as well.
I would try flushing the cooling system again also....hell, it's cheaper than a radiator.
Page generated in 0.56586 seconds with 31 queries
[Output: 58.87 Kb. compressed to 55.55 Kb. by saving 3.33 Kb. (5.65%)]
