Overheating?
Hey guys, I have a kind of odd overheating issue occurring with my blaze. When I got home today I noticed my "check gauges" lamp was on, and the temp gauge was pegged. I immediately popped the hood to see what carnage had taken place. Nothing. The engine didn’t even smell hot, nor was it driving adversely. When I started the truck right after to make sure the fan was spinning the idle was a bit high for a moment then it came back down.
I went to leave about 45 minutes later for a quick 2 mile drive, within 5 minutes of starting the vehicle the gauge was pegged again. When I got out I popped the hood again to check things out. Again, nothing looked out of the norm, no burning coolant smell, no bubbling, no smoke, and she was running fine. The truck is a 2002, 4.3 with a manual, just over 56,000 miles, basically stock and I’ve never had any cooling issues. Temperature would always be at just below mid (210 if my mem serves correct). I searched for a while and couldn’t find anything similar. Anyone experienced anything like this or have any idea as of the cause? My oil is crystal clear, changed 3000 miles ago, so I don’t think anything serious has happened to the motor. Has the sender gone bad perhaps? If it has, is there a way I can test it with a multimeter? Thermostat gone bad? I appreciate any suggestions and information you guys can provide. Thank you. |
Ticket Magnet
Re: Overheating?
Hate to state the obvious but damn...did you check the coolant level???
Re: Overheating?
my 2000 s10 had a similar issue and it turned out the heater hoses were clogged up with what looked like some kind of stopleak or something.So reach back to heater hoses and squeeze them if you here a crunching sound that is your problem.Also check your t-stat they go out all at one time sometimes .YOu can also look at the weep hole at the bottom of your water pump maybe it is on its way out
Re: Overheating?
do you get heat out of the vents?
When my waterpump went bad this happened It was overheating and nothing was hot! lol |
Re: Overheating?
Thanks for the suggestions guys. There was nothing coming out of the weep hole on the pump, nothing dripping under the vehicle whatsoever. My SES light is not on. My coolant level is good, radiator is full. I'll have to check the heater lines later, I backflushed the whole system about 10,000 miles ago, so i dont think it would be an issue, but you never know...
Is there a way to see if the sender is bad via resistance check with a multimeter? If so, what are the parameters of the test? Also with the thermostat, can i test that on the truck? I remember boiling the t-stat on my chevelle back in the day to see whether it was opening, just wanted to know if anyone had a different approach. Thanks all. |
Re: Overheating?
Ticket Magnet
Re: Overheating?
Re: Overheating?
Re: Overheating?
So I got a chance to work on her tonight and me and pops figured we'd start small and move our way up. Swapped the thermostat out, fired her up and let her sit for a while, the gauge never moved past halfway, the t-stat did the trick. I’m stoked. Thanks for taking the time to help me out everyone, later!!
Re: Overheating?
glad it all worked out for you.Not to make you worry or nothing but soon after my t-stat replacement it was time for a water pump.SO keep an eye on taht temp and coolant level. |
